Humax foxsat HDR - What is the LNB trhough for?
Discussion in 'Freesat' started by 123taff, Feb 13, 2009.
  1. 123taff
    123taff Member
    Jan 10, 2008
    16
    I am in the process of ordering the Humax Foxsat HDR recorder.
    I have bought the quad LNB ready for the second lead.
    I have noticed on the back that there are three LNB ports, LNB 1 in, LNB 2 in, but what is the purpose of the LNB1 out port?
  2. Trollslayer
    Trollslayer Active Member
    Feb 11, 2007
    9,304
    +1,393
    It doesn't really do a lot since that won't let you select high or low band or polarisation.
  3. dbaileyuk
    dbaileyuk Member
    Nov 6, 2007
    134
    +17
    Is it so you could use it to feed lnb2 if you only had one lnb cable ?
    It works like that on a terrestrial set top box I have, and also a sat box I have, in the box is a little cable to join them together.
  4. 123taff
    123taff Member
    Jan 10, 2008
    16
    My understanding is that you cannot feed two LNB feeds from one cable, hence the need for a dual or quad LNB and two down leads, so that cannot be the answer.
    On a normal AF feed, you can loop the feed via the Aeriel sockets in and out to TV or DVD recorders so that you can tune on one feed with more than one tuner.
    As you cannot feed the LNB input through to more than one tuner circuit, what does this LNB1 output do. Does anyone actually know over and above speculation?
  5. Geofbob
    Geofbob Member
    Jun 15, 2005
    2,293
    83
    +312
    Dbaileyuk is quite correct, and 123staff is wrong. It's in the Humax Foxsat Manual on Page 16 - http://www.humaxdigital.com/global/products/new_manual/UM_FOXSATHDR_100GB_101308_low.pdf Though of course you don't get full functionality with only one feed, you are able to record any channel, and I think even view a limited range of channels at the same time.
  6. nwhitfield
    nwhitfield Member
    Dec 15, 2005
    1,628
    83
    +261
    If you were using a Single Cable Distribution (SCD/Unicable) then you could loop from LNB1 out to LNB2 in, however that's not presently a supported mode of operation for the HDR, and doesn't seem to work very well in my experience.
  7. Caz41
    Caz41 Member
    Feb 10, 2006
    222
    +12
    I think the box has been designed to work very well with one feed. You can still record 2 channels at same time Eg: I'm recording Jonathan Ross in HD and the James Bond movie on ITV4 at the same time tonight. Granted, it does limit what channels you can watch at the same time but I'm really surprised how well it functions with the loopthrough :)
    Biggest downside is the inability to get the OTA software updates :(
  8. Geofbob
    Geofbob Member
    Jun 15, 2005
    2,293
    83
    +312
    I'd like to receive & record HD, but am in a block of flats where the communal system only allows one feed to each flat, which is why I'm interested in this issue. Therefore I'm particularly pleased that you can actually record two channels at the same time - something I thought you definitely needed two feeds for. But I don't understand your reference to the inability to get OTA updates - how does that relate to the single feed?
  9. 123taff
    123taff Member
    Jan 10, 2008
    16
    So what is the difference in having a twin feed then?
  10. nwhitfield
    nwhitfield Member
    Dec 15, 2005
    1,628
    83
    +261
    At the moment, as part of the installation process, the HDR uses both tuners. It uses one to check things like the postcode data, and then when it decides to fetch a firmware update, switches to the other. If it's previously decided that you have only one cable, then that second stage doesn't work properly - probably because it needs a different mode on each tuner, and with one standard LNB, that's not possible to achieve.
    There is a workaround, which involves unplugging the cable from one tuner and the right stage, and plugging it into the other. But you can't do an automatic update with just one cable at the moment.
  11. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,332
    163
    +3,066
    A lnb is switched by it's tuner to one of 4 bands, Low Frequency, High Frequency, Horizontal Polarised, Vertical Polarised. Giving Low Band Vertical, Low Band Horizontal, High Band Vertical, High Band Horizontal.
    Two cables gives each tuner full access to any band and therefore any channel
    One cable (looped to second tuner), second tuner only has access to channels in the same band as tuner 1 is using (Which is a surprisingly long list)
    If you have Excel - see here
    Hummy.org.uk Forums - View Single Post - What can I record and watch ?
