Humax Foxsat HDR - Issue copying files to USB stick
Discussion in 'Freesat Forum' started by warwickman, Jan 9, 2010.
  1. warwickman
    warwickman Member
    Jun 24, 2009
    3
    Hi guys,
    I'm having a problem copying my recorded programmes from my Humax Foxsat HDR to USB stick (8GB). About 9 times out of 10 the process freezes on the "Copying a file..." screen and makes not progress in 1hr+. The files on the USB after such failed atempts are the .HTM, .NTS and a small (~1MB) .ts file. I have tried several different programmes each about 30 mins long and in SD. Attempting to copy multiple files always fails. Any suggestions?
  2. TonyA
    TonyA Active Member
    Oct 16, 2004
    2,764
    +219
    Have you tried re-formatting the USB stick? Might be worth a shot.
  3. marrtin
    marrtin Member
    Jul 26, 2009
    149
    +10
    The TS is the transport stream file which actually contains the programme data. The other files are used by the HDR to hold information about the programme such as description and dates.
    Make sure the drive is cleanly formatted using the fat32 file system.
  4. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,798
    163
    +3,106
    If formatting fails to fix it's likely a compatibility problem the hdr does not like the chip sets used in some sticks. If it helps my hdr works fine with two 8GB DANELEC ones and also a 8GB emaxUSB one
