Humax FOXSAT-HDR Freesat+Owners Thread
Discussion in 'Freesat' started by Blu-rayx, Nov 24, 2008.
Thread Status:
Not open for further replies.
  1. whatpassword
    whatpassword Member
    Jul 5, 2006
    115
    +5
    Annoying thing happened this evening.
    Wife and I were watching Grand Designs (Ch4) but due to a Tea & Coffee break had it on time slip. We had no other on going recording but at 10pm (also CH4) I'd set a timed recording which once commenced brought us out of the time slip and up to date thus losing the end of Grand Designs. I just automatically assumed the HDR would use the other tuner for the recording and leave us be. That needs addressing.
  2. mccg
    mccg Member
    Jan 9, 2006
    118
    +16
    This is a known issue... but it is very annoying.
    Timeslip gets abandoned whenever a recording stops or starts.
    I can see no technical reason for this, except when both tuners are now required for recordings.
  3. whatpassword
    whatpassword Member
    Jul 5, 2006
    115
    +5
    Thanks. Normally just record everything but the one time we use time slip....:(
  4. dejongj
    dejongj Well-Known Member
    Sep 11, 2003
    28,183
    +4,356
    Hmm maybe I need to test again. Mine seemed ok with one recording and on timeslip last night. It wasn't until the second scheduled recording kicked in I was thrown out.
    I do think humax should handle this more gracefully. On my toppy with mystuff I am at least given a choice at that moment as to which of the three recordings I want to cancel.
    There are a few more things to tidy. I getannoyed by the inconsistency in deleting files. Sometimes it is select and scroll down. Other times it is opt+. And sometimes it is the red button. Why not use a single consistent way.
  5. Geoff_W
    Geoff_W Member
    Nov 2, 2005
    147
    +10
    You can also catch the end of Grand Designs on C4+1 if you remember in time, as this programme often overruns its 10pm end time.
    Geoff
  6. Bonzaimaster
    Bonzaimaster Member
    Feb 8, 2002
    182
    16
    It's a good workaround but it's still poor functionality not to use the other tuner in the first place.
  7. petehb
    petehb Member
    Jan 18, 2009
    28
    Does anyone know how to record a ITV HD program, when reserving a program for future recording on BBC 2 you see a hd logo indicating that the program is also broadcast in HD and you can then move to BBC2 HD channel and reserve for recording but because ITV HD is a red button service can you not select for future recording?
    Pete
  8. 2pods
    2pods Member
    Dec 8, 2003
    183
    +6
    I think if the ITV program is also broadcast in HD, selecting the "enter" on the normal ITV, gives you an option to record/watch in HD if available.
  9. petehb
    petehb Member
    Jan 18, 2009
    28
    Just tried it tonight with the Piers Morgan program and it didnt, I thought that would happen for the BBC2 program but it didnt. Only got the box yesterday so still playing my only grouse is the manual which is pretty poor.
  10. Apollo11
    Apollo11 Member
    Mar 14, 2004
    457
    +22
    Sorry if this has been asked before but can anyone recommend an lnb that will work with this receiver. I should be getting mine tomorrow and no very little about what sort of dish or lnb will be suitable.
  11. Philealing
    Philealing Member
    Nov 24, 2005
    24
    I am due to receive mine next week. I am sure that I have read that Humax supply it WITH an HDMI cable. Can anyone confirm this? The last thing I want to find is that I unpack my box when I return to France to find there is no HDMI lead.
  12. 2pods
    2pods Member
    Dec 8, 2003
    183
    +6
    yes, there is a hdmi cable
  13. kar999
    kar999 Member
    Jun 3, 2005
    +10
    I've set this programme to record tonight and I got the option to record in SD or HD. I pressed the HD option so I trust it will record ITV HD.
  14. petehb
    petehb Member
    Jan 18, 2009
    28
    How did you set it to record to get that option from the epg I didnt get the option, help please!
  15. kar999
    kar999 Member
    Jun 3, 2005
    +10
    Went into the EPG and pressed OK at the Piers Morgan programme, then record and it came up with the option to record in SD and HD (2 boxoes came up) I highlighted the HD box and said OK... I've just checked and it is recording in HD (no red button pressing required).
  16. 2pods
    2pods Member
    Dec 8, 2003
    183
    +6
    I meant to say :
    Go to your program in the epg on ITV.
    Press Enter/OK/select (I'm using a Harmony One so it may be different)
    You should have a small menu asking giving you a choice to watch, record, record whole series.
    IF the program on ITV is also being broadcast in HD, the display tells you and you can then select HD or SD.
    Not every prog on ITV is broadcast in HD, usually football.
  17. rapidone
    rapidone Member
    Oct 15, 2005
    181
    +4
    No idea at all, ITV HD doesnt work for me at all, all I get is a black screen.
  18. petehb
    petehb Member
    Jan 18, 2009
    28
    Many thanks it works I was using the record button which does not give the option, still no mention in the manual.:clap:
  19. TarPot
    TarPot Member
    Dec 16, 2002
    2,338
    63
    +151
    I have upgraded the HD in my Foxsat box to a 1tb drive. I've put the HD that was in the PVR into a caddy and transfered my recordings back to the PVR from the old HD.
    But I can't get my PC to see the drive I have put in the caddy. Could some one give me some help on how to do this please?
    Thanks a lot.
  20. reghorse
    reghorse Member
    Sep 8, 2006
    52
    +8
    Hi Apollo. Like you just got the humax hdr and tried it with my 60cm dish and the Titanium 0.2db single and signals were 100/100.Then bought a 'Big Sat' 0.2db Twin LNB from Southern Satellite and very good. again 100/100 signal.
    Hope this helps.
    • Thanks Thanks x 1
  21. zAndy1
    zAndy1 Active Member
    Nov 26, 2002
    12,763
    +1,303
    Do a factory reset, that will sort it out
  22. fil1973
    fil1973 Member
    Jul 27, 2008
    Well I was the proud owner of a FOXSAT-HDR for a total of 2.5 hours today. We have been experiencing difficulties with our sky+ for the past few weeks so decided to bite the bullet and see if our local currys had one in. They did and after 20 mins excitement driving home I switched over and booted it up. A it was scanning for channels, low and behold the list of all our missing channels started appearing, ITV, Channel 4 +1, more 4 , in fact all of the channels were there.
    After the set up I switched on to BBC1 and there it was, picture just about the same as it was on sky, flicking up and there was BBC2, up again................. oh dear no ITV1. So it is the same as sky, and yes after trying other channels this was the case (including BBCHD). So it seems that its our reception and not sKy as we first thought. An engineer is coming out from sky in 3 weeks (great service huh?) to look at it at a cost of £65. Not that I am expecting any progress. So my unfortunately I have decided that Freesat is not for me just yet.
    I have a feeling my loss of channels is down to being a flat dweller and sharing a communal dish. I understand I don't have the option to record and view at the same time but am confused as to why I can't even get some channels. Any ideas?
  23. Kingymiller
    Kingymiller Member
    Dec 1, 2008
    13
    3
    Try going to the setup menu & have a look at the signal strength. Alternatively press in info button & in the bottom right hand corner of the info banner will be a signal strength indicator.
  24. Fairfield13
    Fairfield13 Guest
    I have a problem with sound on all channels other than the BBC HD.
    I have an Onkyo reciever,up to acouple of days ago sound level on all channels was fine at volume setting 30, then for some reason all channels other than BBC HD need to be on setting 60+, when i switch to BBC HD i am blown off me chair.
    DVD input is fine, so i assume it has something to do with PVR. Can anyone help? :lease:
  25. GasDad
    GasDad Remembered (1964-2012)
    Mar 28, 2006
    5,392
    +766
    Are any of your neighbours having the same problems ?
    You may of course be the only user of the dish and the problem could be as something as prosaic as a bird buidling a nest in dish etc.
  26. TeeDoubleUDee
    TeeDoubleUDee Member
    Sep 10, 2005
    481
    +31
    Just got back after a week's holiday to find NONE of my scheduled recordings have been made :mad:. There was also no response from the remote till I switched off/on at the rear and let it reboot. The schedule list still shows the recordings I asked for (with past dates) so deleted them. It also shows future schedules for series recording, but not confident these will work either! Has my reboot solved the problem? Why did it freeze in the first place? Should I have left the box on ON or Standby? Why me?
  27. Isle of wight
    Isle of wight Member
    Jan 12, 2006
    163
    +7
    I have a friend who's just had his installed and all works OK but no ITV HD. Looking in the HD programmes menu BBC HD is listed but again no ITV HD.
    Sorry if this has already been covered but any clues??
  28. dejongj
    Sep 11, 2003
    28,183
    +4,356
    There's not much broadcasting on ITV HD, so that's the first thing to check on their website whether they have something on....
    And with regards to the Sound levels on the Onkyo;
    1. Did you check the input levels in the Onkyo setup menu? You can adjust them for each input, and since BBC HD is in AC3 it is louder indeed...Slightly annoying but when using the appropriate sound field setting on the Onkyo can be reduced to hardly any difference...
  29. brian taylor
    brian taylor Member
    Jan 1, 2006
    67
    11
    This may have been asked before
    I have just purchased a Foxstat HD plugging into my Panasonic LZD 85
    Would there be any improvement in upgrading the HDMI cable from the standard one supplied with the box to a Gold or Oxygen one
    As just a bit concernded about picture quality
    They seem to range from about £10 would there be any improvement as there was when I upgraded My Scart Leads on Sky
  30. SoftCentaur
    SoftCentaur Member
    Nov 3, 2008
    32
    11
    +3
    Dunno if I read this right, but if you are looking for the ' ITV HD' channel, there isn't one!
    What happens is when ITV broadcast in HD ( for example, tonight at 20.30 Wild at Heart is available in HD and at 23.15 the Monty Python film is in HD ) when the programme starts, then the 'to view in HD press the RED BUTTON' icon appears.
    If you set the EPG to record such a programme, then it will give you the option to record in SD or HD.
    One thing that got me a little confused at first is that if you have set the EPG to record the prog in SD, then if watching 'live' pressing the RED BUTTON will not switch to HD mode.
    Sadly, the handbook is rather vague in many areas.
Thread Status:
