HulloMail an alternative to Visual Voicemail
Discussion in 'iPhone Apps' started by No1Joker, Jan 7, 2010.
  1. No1Joker
    No1Joker Member
    Jul 25, 2008
    1,757
    +222
    iTunes Store
    in UK and US app store, this is an alternative to visual voicemail. I am testing it with a Vodafone Sim Only and will let you know how well it works.
    Its free BTW. :smashin:
    • Thanks Thanks x 3
  2. Pug72
    Pug72 Member
    May 10, 2003
    1,735
    +189
    Doesn't work with O2 PAYG unfortunately. :(
  3. No1Joker
    No1Joker Member
    Jul 25, 2008
    1,757
    +222
    Its working now, after a bit of keypad fiddling etc.
    I get push notification about 45 seconds after the message and it works exactly like visual voicemail. I only wish i could replace the voicemail button with Hullomail.
  4. RustyIdiot
    RustyIdiot Member
    Sep 22, 2005
    89
    +6
    That's actually quite impressive - thanks for the heads up.
  5. psychopomp1
    psychopomp1 Member
    Nov 19, 2007
    722
    46
    +141
    Could you share your settings (I also have Vodafone pay monthly sim only)?
    I don't get any push notifications when someone has left a message, I have to manually check for messages using the App. Also when setting up my account I had to choose "other network", Vodafone Standard or Vodafone Premium didn't work for me.
  6. No1Joker
    No1Joker Member
    Jul 25, 2008
    1,757
    +222
    Sure, my advice would be to go into the website and change the settings there, because the iphone settings just "flashed" alot and didn't change anything.
    Voda Standard.
    Also be sure to follow the divert procedure (i had to do the #21 cancellation first) then the long setup number.
    • Thanks Thanks x 1
  7. psychopomp1
    psychopomp1 Member
    Nov 19, 2007
    722
    46
    +141
    Thanks mate, works like a charm now:smashin:
  8. No1Joker
    No1Joker Member
    Jul 25, 2008
    1,757
    +222
    I ought to do a floow up post (especially as hutch locked down a dupe from Azzin)
    I used Hullo on Voda for about 5 months.
    +ves
    It worked as a visual voicemail
    Gave Push notifications on messages and missed calls
    -ves
    I experienced large delays between messages being left and then being delivered to my phone.
    I got annoyed with having to delete the missed calls from Hullo and from the phone icon
    It would take a long time from pressing the button to play before actually playing the message.
    Summary:
    In all honesty i have deleted it and i have turned my voicemail off. If someone REALLY wants me, usually they'll ring twice. If they don't then they were probably only trying to sell me something ;)
