HUB 3.0 video streaming issues
Discussion in 'BT' started by trapdoor berk, Jan 13, 2012.
  1. trapdoor berk
    trapdoor berk Member
    Aug 8, 2007
    330
    +40
    Hi Guys,
    I've had the BT home HUB 3.0 for a while now and it seems to be fine, but I can't stream video very well, when my old router did it without any problems.
    The setup I have is my xbox 360 can see my laptop's HDD, so I have my films in a shared folder (windows 7), so I can watch all my films on my laptop's HDD via my xbox 360, this all was fine and good with my old router, but with the BT router the stream stutters all the time and is just rubbish...
    Is this a know problem or can I upgrade some firmware to improve this?
    thanks in advance
  2. Foster
    Foster Well-Known Member
    Sep 25, 2011
    10,177
    +3,176
    I stream to the PS3 and it is fine so I'm not sure
  3. beerhunter
    beerhunter Active Member
    Nov 9, 2005
    6,335
    +759
    Are all the devices connected via wired Ethernet?
  4. Foster
    Sep 25, 2011
    10,177
    +3,176
    Nope my PC is wired my laptop is wireless and my ps3 is wireless
  5. beerhunter
    Nov 9, 2005
    6,335
    +759
    Actually I meant the OP. :D
  6. Foster
    Sep 25, 2011
    10,177
    +3,176
    Damn you :D
  7. trapdoor berk
    Aug 8, 2007
    330
    +40
    My 360 is wired direct to my router, but my laptop is wireless.
  8. beerhunter
    Nov 9, 2005
    6,335
    +759
    Well there you may have it then.
    First try the laptop with wired Ethernet and if the problem goes away, take a read of the WiFi FAQ. (Especially the bits about channel conflict and how to fix it.)
    • Thanks Thanks x 1
  9. trapdoor berk
    Aug 8, 2007
    330
    +40
    Ok cool thanks, will check it out, and yes if its all wired I have no problems..
  10. trapdoor berk
    Aug 8, 2007
    330
    +40
    Sorry I am being blind, where is the WiFi FAQ?
  11. Chris Muriel
    Chris Muriel Active Member
    Jun 14, 2002
    6,860
    +703
    • Thanks Thanks x 1
