HTC Desire save photos to SD card
Discussion in 'HTC Mobile Phones' started by rickinyorkshire, Jan 27, 2012.
  1. rickinyorkshire
    rickinyorkshire Active Member
    Sep 27, 2006
    5,138
    +494
    Hello,
    My gf desire says it's running out of space, i checked and her photos she takes with her camera are saving to internal memory instead of SD card. I can't find an option to change this, can anyone help?
    Thanks.
  2. Minkey1
    Minkey1 Member
    Jan 4, 2012
    105
    +8
    Camera/Settings/Save To, or similar wording ?
  3. rickinyorkshire
    Sep 27, 2006
    5,138
    +494
    Nope, no options at all in camera to select where to save to...
  4. scrapbook
    scrapbook Active Member
    Jan 12, 2002
    6,607
    +431
    I thought they saved to SD by default
  5. scrapbook
    Jan 12, 2002
    6,607
    +431
    All pics and vids do get saved to the SD card by default. If you go to Files/Phone files/dcim/Camera and long press on any file, and then choose "info", you will see the folder is listed as /mnt/sdcard/dcim/Camera. _______________
  6. rickinyorkshire
    Sep 27, 2006
    5,138
    +494
    Nope, hers are saved to internal memory, not /sdcard which is what i'm wanting to change.
  7. scrapbook
    Jan 12, 2002
    6,607
    +431
    So you checked that location on SD card?
  8. rickinyorkshire
    Sep 27, 2006
    5,138
    +494
    They are not being saved to her memory card at all. I have looked all over her phone for some settings to change - camera/images etc and none to be found.
    I have an HTC Desire HD and i thought i'd check mine now and i too am unable to find an option to change where to save pictures taken with the camera. Very strange.
  9. Minkey1
    Minkey1 Member
    Jan 4, 2012
    105
    +8
    Does the phone *see* the card, and can you browse to it ?
  10. maverick52
    maverick52 Member
    Jul 22, 2005
    217
    +6
    Checked mine saves to sd dcim /100media. Used an app called explorer to check try moving an app to the sd card to see if the card is ok
  11. _Sion
    _Sion Member
    Sep 26, 2006
    678
    43
    +106
    My thoughts exactly, it sounds like the phone isn't seeing the SD card so is saving to main memory.
