HTC Desire Headphone Alternatives
Discussion in 'HTC Mobile Phones' started by step, Apr 5, 2010.
  1. step
    step Member
    Jul 5, 2006
    81
    9
    Anyone know of any headphones that work with the Desire and also have a remote to control the music without the need to take the phone out of the pocket. The supplied headphones do not fit my ears so need some in ear ones similar to my old sony ericsson ones.
    Not sure if all headphones will pick up the FM Radio?
    Have thought about the Sony Ericsson MW600 Play.com (UK) - Mobile - Free Delivery but not sure if the bluetooth will work with this phone.
    As a cheaper alternative maybe Nokia WH_701 Play.com (UK) - Mobile - Free Delivery but don't know if the radio will work through these?
    Any help would be great.
  2. RobM
    RobM Well-Known Member
    Dec 29, 2006
    13,114
    +2,184
    Forget Bluetooth if you want FM Radio, as the radio requires the wired headphones to use as an aerial.
  3. chrism_scotland
    chrism_scotland Active Member
    Nov 5, 2006
    3,926
    +230
    Those Sony Ericsson ones have an FM radio built into them
  4. step
    step Member
    Jul 5, 2006
    81
    9
    As chrism says those sony bluetooth headphones have fm radio built in but not sure how they work with the music player on the desire
  5. RobM
    Dec 29, 2006
    13,114
    +2,184
    I can only give you my personal experience and opinion... but the FM reception was poor when I had them for a day to test. Bluetooth playback and control was great, sound quality as expected given the cost, which was somewhat flat and lifeless with boomy bass. But about as good as you'll find in this pricerange, on-par with the Sony EX-71 IMO.
  6. step
    step Member
    Jul 5, 2006
    81
    9
    Ive found that the reception with the built in radio on the desire to be pretty bad the times ive tried it thats why i was hoping maybe the sony's might be a good option or alternative headphones might give better reception.
  7. RedAl
    RedAl Well-Known Member
    Dec 14, 2006
    9,988
    +2,577
    What about these:-
    Sennheiser CX300 In-Ear Headphones - Products
    and this for allowing you to use the headphones as a mic too in order to answer calls:-
    HTC: Accessory store: Pocket PC Headsets + Handsfree: HTC Desire Audio Adaptor for 3.5mm to 3.5mm HS U350 (with Stereo Headset + HTC Logo, Retail Pack): Description
    Hope thats what you were looking for. if not forgive me :D
    EDIT: fiddlesticks, just noticed you wanted something that remotely controlled the music. Looks like this suggestion is a steaming pile of do-do. Pleae ignore my ramblings
  8. crazy4ker
    crazy4ker Member
    Feb 17, 2009
    67
  9. chrism_scotland
    Nov 5, 2006
    3,926
    +230
    I've just noticed that my Skullcandy iPhone earphones skip tracks on Spotify when I hit the call button.
    Has anyone else got the MW600 bluetooth earphones yet would love to know how well they work.
  10. Oggie
    Oggie Active Member
    Jul 11, 2007
    7,200
    +613
  11. Staberinde
    Staberinde New Member
    Dec 11, 2006
    7
    3
    So I just got one of these to use with my HTC Desire:
    GriffinSmartTalk
    * It has a TRRS 3.5 jack
    * This means one click plays/pauses tracks, a double click skips the track
    * A single click picks up an incoming call
    The caveat is that the default HTC music player doesn't allow track skipping. I'm using Mort instead, and the adaptor works fine with it.
    I have my Sennheiser Cx300s plugged into the adaptor and can receive FM radio perfectly.
    Hope this helps!
    • Thanks Thanks x 1
  12. Zsev
    Zsev Member
    Aug 12, 2009
    55
  13. Ivor_Biggern
    Ivor_Biggern Member
    Nov 6, 2003
    1,966
    +100
    I tested my Sennheiser PX100 headphones on my HTC Desire, when using the FM radio its very hit and miss. You get some stations crystal clear whilst others are distorted, thats obviously because of no antenna in the headphones.
    For listening to music tracks they are superb, i would certainly be interested in a similar pair of Sennheiser headphones that had a built in antenna.
  14. phrozenpenguin
    phrozenpenguin Member
    Jul 23, 2009
    3
    It does help but please can you confirm the single click will also end a call. I.e. you can use the headset to pickup and end calls, regardless of music status, without having to actually touch the handset?
  15. Staberinde
    Dec 11, 2006
    7
    3
    Yes, I can confirm this is the case. While music is playing, one click picks up an incoming call and the next click ends the call.
    And a double-click will start the music player from scratch too. Which means you can just plug in the jack, double-click and go - without going through the lockscreen to start your music app.
    BTW, I'm now using bTunes. Better headset integration that Mort.
  16. Singh400
    Singh400 Well-Known Member
    Feb 21, 2006
    17,830
    +3,416
    I have got the Sennheiser CX300 headphones. In fact we actually have around three pairs of the CX300's around the house. They are that good.
  17. phrozenpenguin
    Jul 23, 2009
    3
    Staberinde - thanks for the update. I will get a cable.
  18. Scott9
    Scott9 Member
    Jan 31, 2010
    19
    I've got CX550's for £40 and they're outstanding.
  19. portisgreg
    portisgreg Member
    Aug 4, 2010
    3
    Hi Step, I had the same problem, I bought some Griffen £19.99 Tune Buds because it said they are able to skip tracks etc but it doesnt work with the standard desire. It only has the single button to skip, pause, answer calls etc.
    However I just downloaded "Music Player" from the app store for free and this uses the same single button control as the iPhone. The interface isn't as nice but there may be other alternatives out there if anyone can recommend any??
    So now I'll buy some sennheiser/bose/klipsch single button control headphones.
    Hope that helps.
    Greg
    • Thanks Thanks x 1
