HP N36L/N40L/N54L Microserver Updated AHCI BIOS Support.
Discussion in 'Networking & NAS' started by TheBay, Sep 29, 2011.
  1. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    Title needs updating, this BIOS works on N36L/N40L/N54L
    As we know, the HP Microsever only supports AHCI via the 4 internal drive bays and SATA connections 4/5 (Ports start from 0) are IDE mode.
    There is a Russian BIOS floating around, but no one is really sure what exactly has been changed on this and also how up to date it is - This BIOS give the option to enable AHCI mode on those ports.
    However personally with a device like a server, I wouldn't want to put anything on there that could compromise things and want to keep up to date with the BIOS Updates HP issue.
    So I have been modifying my own BIOS files with official tools, I thought I would put a thread up here so I can share/discuss these files with everyone. I will also modify every update so we can keep this functionality.
    I have stamped the BIOS files with revision information, including my forum name, which is displayed on POST so you know the BIOS you have has come from here/me.
    Can a mod let me know if we can make this sticky and i'll update it with each revision, is there facility to upload the BIOS file here? its 2.0mb. If not what websites are permitted on here that I can upload the file to?
    19/10/2011
    Updated BIOS
    Added FAN Option (Not sure what this does exactly, but have a play)
    Simplified AHCI/IDE Setting:
    Removed - AHCI Menu for configuration/drive status
    - IDE Menu configuration/drive status
    30/09/2011
    Microserver AHCI BIOS O41072911
    Added
    - AHCI Support for SATA ports 4/5 (Ports start at 0)
    - IDE Menu configuration/drive status (for those who use IDE mode)
    28/02/2008
    23/2/2013
    Changed to easy installation method,
    Unrar file, put USB stick in to PC, within that folder double click on RunMe. Follow instructions on screen, then exit and put the USB stick in the Microserver and reboot to update BIOS.
    TheBay_Microserver_Bios_041.rar
    Working on newer version of Bios, will post soon.
    • Thanks Thanks x 44
  2. Methanoid
    Methanoid Member
    Oct 26, 2005
    801
    +18
    Mediafire would be fine IMHO
  3. jerrymac
    jerrymac Member
    Dec 14, 2006
    246
    +29
    @TheBay: Link?
  4. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    I'm waiting on a Mod to get back to me before I post any links on here, as I don't know what sites are permitted.
  5. theronkinator
    theronkinator Member
    Jul 14, 2009
    729
    28
    +95
    Use any doesn't matter.
  6. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    *updated and removed link*
    Added
    Enjoy.
    • Thanks Thanks x 5
  7. tezza77
    tezza77 Member
    Oct 8, 2009
    10
    3
    I mean absolutely no disrespect by this but I'm a little nervous about flashing someone else bios image but I figure I do want AHCI for SATA 4 & 5.
    Has anyone else flashed this yet and can confirm it working?
  8. Benoe
    Benoe Member
    Jul 5, 2011
    14
    3
    +5
    I will and let you know, ok?
  9. tezza77
    tezza77 Member
    Oct 8, 2009
    10
    3
    Thanks but it doesnt matter now, decided to man up and flash it anyway.
    Seems to be working thanks OP :smashin:
    • Thanks Thanks x 1
  10. Methanoid
    Methanoid Member
    Oct 26, 2005
    801
    +18
    You also mentioned memory timings and possible over clock options?
  11. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    Yes, I will have a look in to that, the option is there.
    But would have to come with a warning. As the main caveat with the Microserver is a lack of cooling for the main board.
  12. jerrymac
    jerrymac Member
    Dec 14, 2006
    246
    +29
    I installed on my two microservers and both working fine one with ESXi 5.0 and the other with Win2008 R2. :smashin:
    • Thanks Thanks x 1
  13. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    Just had a play around with Solaris 11 (text install, no gui) on the Microserver.
    Can confirm Solaris 11 Express supports AHCI on the Microserver out of the box, with ALL 6 ports (using this BIOS)
    ~$ prtconf -D
    Code:
      pci103c,1609, instance #0 (driver name: ahci)
                disk, instance #1 (driver name: sd)
                disk, instance #2 (driver name: sd)
                disk, instance #3 (driver name: sd)
                disk, instance #4 (driver name: sd)
    That's with 1 disk in the ODD bay (OS Drive) and 3 Disks in the Hot swap bay, i'm getting over 220mb per sec sequential reads using 2x2TB and 1x1TB in Raidz and not even set up properly yet, but it's works and is saturating my gigabit network!. :)
    Solaris 11 seems to work well.
  14. MikeK
    MikeK Member
    Oct 9, 2004
    2,231
    83
    +320
    One slight caveat that anyone considering Solaris11 should be aware of, is that the latest ZFS pool versions are Oracle only (at least for the moment), so if you build your pools with the default pool version, then you'll be stuck on Solaris11, as nothing else which supports ZFS will support pool versions above 28 AFAIK (sol11express 11-2010 uses pool version 31 by default, and the latest Early Adopter release (EA) uses pool version 33)
    Probably best to create your pools using something like pool version 22 (perhaps lower, depending on what pool version your potential target OS supports - FreeNAS8 for instance only supports up to version 15 AFAIK), at least then you could switch to another OS if you want without having to destroy and recreate your pools. You can always upgrade the pool version later if you feel you need any of the features the latest pool versions provide.
    However there is no reverse option, you cannot downgrade the pool version - once it's at version 31 or 33 there's no going back to an earlier version (not without destroying and recreating the pool that is)
    • Thanks Thanks x 1
  15. Benoe
    Benoe Member
    Jul 5, 2011
    14
    3
    +5
    I also made the update, it is working ok. I didn't need to update any settings.
  16. Benoe
    Benoe Member
    Jul 5, 2011
    14
    3
    +5
    Let me copy my microserver bios wishlist here:
    1. S3 suspend
    2. shorter bios boot, if the previous one is not possible
    3. adjustable fan speed
  17. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    1. S3 suspend
    This doesn't seem possible yet, will keep looking in to it though
    Might be possible, can disable optional prompts/option bioses
    To speed up or slow down?
  18. Benoe
    Benoe Member
    Jul 5, 2011
    14
    3
    +5
    Could be both. I also read, that you cannot install some noiseless but powerful fans, because there is a limit in fan speed, the microserver doesn't start below: link
    "This is a PWM version of the popular SlipStream series, with a rated maximum speed of 1300 RPM. After the initial full speed burst at turnon, the fan slowed to an extremely slow speed, which caused a fan error message to display and the system to power down immediately. The system wants to see a faster fan."
    • Thanks Thanks x 1
  19. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    Thanks for that info MikeK,
    Though will probably stay with Solaris 11 but not on the Microserver, in the process of pricing up a SandyBridge Xeon system to do VT-d, will run it on ESXi. Really surprised how well the Microserver copes with ZFS though :)
    It is possible to disable fan control through the BIOS,I will have a play around with that and see if the server will ignore fan speeds?
  20. Benoe
    Benoe Member
    Jul 5, 2011
    14
    3
    +5
    To tell the truth, currently I'm not planning to replace the fan. But I know that others want to or already had problems with it.
    But if there would be an option for the fan to slow it down to become more quiet, and consume less power, I would use it.
    I would be happy to have any option that makes the microserver faster to boot (or wake up from sleep), consume less power, make more quiet. Others may have other preferences. (like cpu overclock, running games, etc.)
  21. DIABLOS
    DIABLOS Member
    Jul 25, 2009
    40
    +11
    The ability to overclock the CPU by a 100Mhz or 2 would be awesome!
  22. theronkinator
    Jul 14, 2009
    729
    28
    +95
    The main thing I miss is the ability to put the Server to sleep.
  23. gavjbrown
    gavjbrown Member
    Oct 4, 2006
    199
    +11
    Once I have flashed this Bios, do I have to change any bios settings.
  24. TheBay
    TheBay Member
    Jan 1, 2007
    923
    46
    +144
    To enable AHCI on all ports, go to Southbridge Config, SATA 4/5 and disable sata 4/5 IDE mode.
    • Thanks Thanks x 4
  25. gavjbrown
    gavjbrown Member
    Oct 4, 2006
    199
    +11
    Thank you. :)
  26. gavjbrown
    gavjbrown Member
    Oct 4, 2006
    199
    +11
    Could someone tell me what to type at the command prompt when updating with this bios. Thanks
  27. Benoe
    Benoe Member
    Jul 5, 2011
    14
    3
    +5
    Pls read the "AHCI BIOS Installation.txt" wich is packed together with TheBay's bios file.
    • Thanks Thanks x 1
  28. gavjbrown
    gavjbrown Member
    Oct 4, 2006
    199
    +11
    I did read the txt file and there is no mention of typing at the command prompt,
    so I assume I did something wrong when making the usb stick and I shouldn't be getting that prompt.
    Thanks for the reply, just trying to set my backups up now and will have another look at the bios later.
  29. Mysteron17
    Mysteron17 Member
    Oct 3, 2011
    2
    Hi, a quick question. I have already installed WHS2011 on my server using a HDD in the ODD bay (currently IDE mode I assume). If I flash and enable AHCI on this port will I need to do anything or does it just work...only faster? Thx.
  30. Benoe
    Benoe Member
    Jul 5, 2011
    14
    3
    +5
    You will probably get an answer in Microservers original topic: link
    • Thanks Thanks x 1
