how to ?
Discussion in 'Cables & Switches' started by jaypam27, Dec 10, 2012.
  1. jaypam27
    jaypam27 Member
    Nov 29, 2012
    9
    Hi all,
    I just got some speaker cable, Audioquest FLX-SLiP 14/4, It has 4 strands, green, red, black and white.
    I am connecting to a pair of B&W 685's and then into a Yamaha RX-V373.
    I am quite new to this, does anyone know what color strand will connect to which terminal on the speakers and the amp ?
    Any help would be much appreciated, Thanks
  2. testdasi
    testdasi Member
    Mar 24, 2011
    226
    +22
    On the speaker ends, it doesn't really matter which colour to which terminal, as long as the same colour goes to the same polarity on the amp.
    For biwiring: If you connect [High+ to Red, Low+ to Green], [High- to black, Low- to White] then on the amp side, [Red and Green to the + terminal] and [Black and White to - terminal].
    Can't remember if the 373 can bi-amp (passively) but if it can that will be slightly different to biwire case above.
    Since you are new, I recommend the followings:
    • Use an easy to remember convention. Like the example above, coloured strands to +, no colour to -. Or since your speakers are B&W, no colour to +, coloured to -. Whichever way, keep it consistent to all the speakers.
    • Unless your equipments are going to be in the same place for a long time, get some good banana plugs. They make things a lot more convenient to rearrange stuff as you can plug and unplug with ease (instead of fiddling with cable and connectors). They also reduce the chance of any loose strand shorting your terminals.
    Nice speakers, btw. :thumbsup:
  3. jaypam27
    jaypam27 Member
    Nov 29, 2012
    9
    Thankyou so much, I shall give it a try when I get home.
    Yes they are lovely speakers, my babies :D
  4. jaypam27
    jaypam27 Member
    Nov 29, 2012
    9
    Sorry, forgot to ask, I assume I will need to connect 2 strands to one terminal on the amp side ? There are only 2 + and 2 -, is this correct ?
    Thanks,
    J
  5. testdasi
    testdasi Member
    Mar 24, 2011
    226
    +22
    Yes, unless you are bi-amping, you connect the 2 cable + to the - terminal (for example, if you are connecting front right speaker then both + from the front right speaker goes to the amp front right + terminal) and 2 cable - to the amp - terminal.
  6. jaypam27
    jaypam27 Member
    Nov 29, 2012
    9
    ok thanks, if i choose not to bi-wire i can just use 2 of the 4 strands right ?
    i read a thread where bi-wiring seems as though it is not worth doing ?
    thanks for your help
  7. testdasi
    testdasi Member
    Mar 24, 2011
    226
    +22
    If you are not bi-wiring then connect both the red and green to a single + terminal on the speaker and the other end (of both) to the + of the amp; and the black and white to the a single - terminal on the speaker and the - on the amp.
    Of course, you need 2 "bridges" to connect the 2 + on the speakers together (and the 2 - together). Those should be included with the speakers.
    Yes, bi-wiring is not worth doing. However, your cable is bi-wiring cable (it has 4 cores) so just using 2 of the 4 strands is wasting it.
  8. BigChris
    BigChris Member
    Dec 15, 2010
    89
    11
    +4
    digging up and old thread,
    how did you get on with biwiring the FLX-SLiP 14/4
    I heard it causes it to lose sound quality?
  9. larkone
    larkone Active Member
    Apr 21, 2006
    2,472
    83
    +362
    It will only lose quality if the cross sectional area of the cable is insufficient for the length of cable needed and the impedance of the speakers, otherwise it is just copper wire underneath its fancy clothing and associated marketing - Semi-Solid Concentric Packed Conductors is a good one, so that's strands of wire then :smashin:
  10. Superfly76
    Superfly76 Member
    Apr 5, 2008
    80
    +3
    Hi all!
    I've got these cables which I use with the Marantz M-CR610 and Q Acoustics 2020i and the shop where I bought the cables say:
    RED & WHITE together for RED terminals
    BLACK and GREEN together for BLACK terminals
    Which I've done. My question is, is it better to have it this way or have it as mentioned above in previous posts. My speaker end has bananas, maybe red & white together etc... Any thoughts?
    Thanks!!
    Superfly
  11. Philip4242
    Philip4242 Member
    Jan 15, 2008
    743
    28
    +94
    As has already been said 'On the speaker ends, it doesn't really matter which colour to which terminal, as long as the same colour goes to the same polarity on the amp.'
    There is no difference at all between the 4 cable cores; other than the insulation colour, which is simply to aid identification of the 4 cores at each end.
  12. Superfly76
    Superfly76 Member
    Apr 5, 2008
    80
    +3
    Many thanks!!!!
