how to reset my philips tv
Discussion in 'TVs' started by Piram, Feb 24, 2009.
  1. Piram
    Piram Guest
    I want to reset my philips tv model 32DW6557/05.
    the reason for this i want to tune freeviw program. I am unable to access digital menu using my remote. analogue mode works fine with remote, in analogue mode i can access install menu to scan for analogue program. but in digital mode i can't see the install menu.
    Manual says when the tv in factory default setting it will start scan both Analogue and digital program when i switch on the tv for the firstime. In this way i can get my digital channal tunned.
    thanks any help in this problems.
    Piram
  2. JayCee
    JayCee Active Member
    Jan 20, 2004
    15,754
    +1,576
    There is no "reset" option on this model which uses the Philips A10E chassis with the infamous "Painter" Ic chip...just do a search of this forum using Painter as the search term and you'll come across many posts...the symptoms are many and varied when this Ic goes faulty...Crt flashover could also have corrupted the "Option Bytes" leading to no access to the digital menu.
    The option bytes can be reset but it is complicated and can render the set useless if done incorrectly...it's a job for an experienced technician.
  3. Piram
    Piram Guest
    thank you for your advice.
    Piram
