How to connect iPhone to computers LAN connection?
Discussion in 'iPhone Forum' started by kazino21, Mar 30, 2010.
  1. kazino21
    kazino21 Member
    Mar 6, 2006
    631
    +4
    I am in a hotel in Africa where I have internet via a wired LAN connection. Without a wireless router would it be possible to get internet on my iPhone through USB connection or wifi or bluetooth?
  2. mickyd67
    mickyd67 Member
    Jun 28, 2005
    581
    +14
    There is a way to set your computer up so you can access the web "through" it - so I'd say it's possible.
    Not 100% sure on how to set it up, I'll have a wee look at the moment.
  3. mickyd67
    mickyd67 Member
    Jun 28, 2005
    581
    +14
    Depending on what OS you're using.
    I'm on Win7.
    Go into Start > Network > Network and Sharing Center
    Where is says Connections: "xxxconnection namexxx"
    Click that
    Then click Properties
    Then click Sharing
    You should then see this - by clicking that box it should turn your PC into an access point:
    [​IMG]
  4. kazino21
    kazino21 Member
    Mar 6, 2006
    631
    +4
    I have tried sharing the LAN connection, but it is still not working.
  5. kazino21
    kazino21 Member
    Mar 6, 2006
    631
    +4
  6. iandrews
    iandrews Member
    Jul 17, 2003
    840
    63
    +288
    I did this just last week while away on holiday with a Windows 7 Netbook.
    You need to set up your wireless card as a Ad-hoc network. Then do almost as mickyd67 said but you need to share your "wired" connection.
    When setting up the Ad-Hoc wireless I found that setting the encryption to WPA didn't seem to allow the iPhone to connect, so I set it to WEP instead.
    Ian.
  7. kazino21
    kazino21 Member
    Mar 6, 2006
    631
    +4
    Have been trying all the various options suggested and followed the websites, but still no success. Any other suggestions as to a technicality that I might need to change somewhere.
  8. kazino21
    kazino21 Member
    Mar 6, 2006
    631
    +4
    Ok, Lord knows how but after leaving it alone for an hour it just started working by itself :)
    Thanks for all your help and for anyone wanting to do the same it does work just follow one of the guides and wait a while for it to do whatever settings it has to process, I guess I was expecting it to work after waiting for a minute or two.
