How far are you from your exchange?
Discussion in 'ISPs & The Internet' started by sore napper, Aug 11, 2007.
  1. sore napper
    sore napper Active Member
    Sep 2, 2006
    3,620
    +249
    Your internet speed depends on your distance from the exchange and the quality of the lines. As if you need me to tell you that, but
    For the first time, I found out how far form my exchange I am.
    Approximately 671 meters from the exchange (straight line distance) :clap:
    How far from your exchange are you?
    http://www.samknows.com/broadband/checker2.php
    Enter phone number or post code, and click the BT ADSL box under Summary:smashin:
  2. smashie
    smashie Member
    Apr 20, 2006
    806
    +54
    he he 295 metres away..:clap:
  3. telford_mike
    telford_mike Member
    Feb 19, 2006
    215
    +16
    According to BT Wholesale, your line should be able to support a 0.5Mbps or greater ADSL connection.
    And 0.5 Mbps is exactly what I get :thumbsdow
    September 2009 before things get any better apparently :mad:
  4. calypso69er
    calypso69er Member
    May 25, 2006
    275
    +21
    2.56km..........
  5. geomuss
    geomuss Member
    Jul 10, 2006
    2,041
    +178
    whooo! beat this boys !!!!
    BT ADSL broadband availability
    You are connected to the Musselburgh telephone exchange.
    ADSL is available in your area
    Your exchange is also enabled for ADSL Max services
    According to BT Wholesale, your line should be able to support a 4Mbps or greater ADSL connection via ADSL Max.
    Standard ADSL RAG results:
    [BT ADSL Code: GEGEGEC] You can receive 2Mbps ADSL
    [BT ADSL Code: GEGEGEC] You can receive 1Mbps ADSL
    [BT ADSL Code: GEGEGEC] You can receive 512Kbps ADSL
    [BT ADSL Code: GEGEGEC] You can receive 256Kbps ADSL
    You are approximately 80 metres from the exchange (straight line distance).
    However, there is another service on your phone line (e.g. ADSL, LLU, DACS, etc) that would prevent you from ordering a new ADSL connection.
    Your BT ADSL code is: GEGEGEC
  6. Xabi17
    Xabi17 Member
    Aug 9, 2007
    414
    +17
    2.35km. :(
  7. KyleS1
    KyleS1 Active Member
    Jan 23, 2007
    8,490
    +772
    1.31km for me. That is still close!
  8. Wild Weasel
    Wild Weasel Active Member
    Dec 11, 2005
    5,327
    +632
    944 metres
    "your line should be able to support a 8Mbps or greater ADSL connection via ADSL Max"
    There's no LLU available yet unfortunately.
  9. ncsltd
    ncsltd Member
    Jul 3, 2007
    3
    3
    very close...
    You are connected to the Eastbourne telephone exchange.
    According to BT Wholesale, your line should be able to support a 6.5Mbps or greater ADSL connection via ADSL Max.
    Standard ADSL RAG results: You can receive 2Mbps ADSL
    You are approximately 188 metres from the exchange (straight line distance).
    Your BT ADSL code is: GEGEGEZ
  10. Wild Weasel
    Dec 11, 2005
    5,327
    +632
    I know for a fact that many of the exchanges have their own ADSL connections for the engineers to use. I bet they're pretty quick.:D
  11. tvdavid
    tvdavid Member
    Feb 20, 2006
    2,343
    +102
    I get this from the site
    Congratulations, you are in a broadband enabled area.
    The following services are available in your location:
    BT Wholesale ADSL
    BT Wholesale ADSL Max
    TalkTalk (CPW) LLU
    Sky Broadband / Easynet LLU
    Tiscali LLU
    21CN PSTN migration due Apr-Jun 2009
    According to BT Wholesale, your line should be able to support a 7Mbps or greater ADSL connection via ADSL Max.
    You are approximately 161 metres from the exchange (straight line distance).
  12. triplea4uk
    triplea4uk Member
    Jan 12, 2002
    1,946
    48
    +90
    Straight line distance means nothing your line can still be more then 3 times that length also I don't trust samknows for exchanges it seems to have some in the wrong locations.
  13. williemaykit
    williemaykit Member
    Jan 8, 2006
    1,295
    +169
    I am 1.6m and get between 8 to 10Mb with BE which is a lot better than the 1Mb I got on a BT ADSL Max service.
  14. tvdavid
    tvdavid Member
    Feb 20, 2006
    2,343
    +102
    My Line Attenuation is 4.5 my router says so I must be very close to my one.
  15. 961
    961 Active Member
    Oct 13, 2006
    4,617
    +667
    I'm not sure how much further this information takes us
    I'm about 1.5 miles from my exchange in a straight line
    But I'm actually around 5 miles from the exchange as the wire travels
    Initially I was told broadband would be problematic and might need an engineer to connect at 512
    I eventually got connected at 1mb
    After upgrade of some old bits of line I now get 3mb
    Straight line distance means very little
  16. Someguy
    Someguy New Member
    May 8, 2007
    519
    +4
    865 meters. On Sky MAX and getting 8000 Kbps :thumbsdow
    Maybe BT are still stabilising my line. In my experience though after they stabilise it the line is slower.
  17. Singh400
    Singh400 Well-Known Member
    Feb 21, 2006
    17,788
    +3,375
    1.21 KM can easily pull 850 kb/s some I'm happy. :D
    At my old house it was 666 metres! :D
  18. nealgs
    nealgs Guest
    i remember doing this check about 4 years ago, when the checker used to report that we were 620miles from the exchange, o how we laughed :eek: :rotfl:
    Anyways, they now report we are 3.65km IIRC and are currently stuck at 512K connection, although i'm hoping that ADSL2+ will give us a better rate.
    Looking at moving from PIPEX to Be or possibly Sky as we already have Sky+ multiroom.
    Gary
  19. StealthHD
    StealthHD New Member
    Jul 22, 2007
    1,077
    +49
    427m straight line. with BT I would get 7.5meg:clap: but I'm with be so I get 20+meg download speeds:eek:
  20. PJTX100
    PJTX100 Active Member
    Dec 21, 2004
    8,119
    +573
    4.11Km :)
    I usually get around 1.2Mb download and 448K upload (which i'm actually more interested in).
    Sometimes the line drops when it rains. :laugh:
  21. steery1
    steery1 Member
    Oct 1, 2007
    I'm getting this.................................
    Can anyone tell me what "Standard ADSL RAG results" means? :confused:
  22. Mr THX
    Mr THX Member
    Nov 26, 2002
    1,270
    +30
    Less than half a mile and still get poor download speeds :(
  23. steery1
    steery1 Member
    Oct 1, 2007
    Anybody know what this means?
  24. Rygar
    Rygar Member
    Jun 5, 2006
    1,746
    +279
    Stands for Red Amber Green, like traffic lights. There are various criteria to establish colours given.
    More about it on Kitz's site: http://www.kitz.co.uk/adsl/RAGtest.htm
  25. dej23
    dej23 Member
    Dec 8, 2003
    2,240
    48
    +49
    bet no one can beat this...
    You are approximately 66 metres from the exchange (straight line distance).
  26. bob1
    bob1 Active Member
    Nov 7, 2002
    4,304
    +144
    I'm 168m ..
    My brother can't be anymore than 20m ,he lives 2 doors away from the exchange.
  27. tvdavid
    tvdavid Member
    Feb 20, 2006
    2,343
    +102
    My exchange is just across the road here.
    You can see all the stuff in side it as well.
    There loads of lights on things may be there servers?
  28. sore napper
    Sep 2, 2006
    3,620
    +249
    That actual sounds very cool :cool:
    Did I just say cool?:rolleyes: I think that I did:cool:
  29. tvdavid
    tvdavid Member
    Feb 20, 2006
    2,343
    +102
    Our exchange has a gym on the top of it as well.
  30. sore napper
    Sep 2, 2006
    3,620
    +249
    :eek:
    WOW:eek:
