How Do You Charge PSP Via USB
Discussion in 'PS Vita & PSP' started by DonkeyDave, Jan 7, 2006.
  1. DonkeyDave
    DonkeyDave Member
    Jan 8, 2005
    57
    I can't find my normal PSP charging lead, so will have to charge via my USB.
    Do you have to have the PSP on or off when charging?
    It is currently off, with the power led lit up, is it charging?
    I did have it plugged in earlier whilst switched on, and chose USB option in the menu, the battery icon seemed to be flashing, but non of the battery bars seemed to be filling.
    Any advice appreciated.
    Thanks In Advance:)
    EDIT:
    Sussed it, PSP has to be turned off!!
  2. Nick_UK
    Nick_UK New Member
    Nov 13, 2004
    9,748
    +315
    I didn't know you could ! :smashin:
  3. 44hollowpoint
    44hollowpoint Member
    Jan 6, 2006
    11
    Not strictly true. A PSP will charge from USB even if you are playing it, it will just take longer to charge.
    I take it you are using a split USB/Power lead?
  4. gbcasual
    gbcasual Active Member
    Nov 5, 2002
    2,670
    +512
    Game do the USB/power lead for £6.99 on it's own, or as part of various kits (with screen protectors etc).
    http://shop.game.net/ViewProduct.aspx?cat=11234&mid=326193
    Alternatively, choose an ebay auction carefully (be wary of postage) and get one for £3-4.
    The PSP can be on or off while plugged in but in my experience it seems to only extend battery life rather than actually charge it if you're playing. Still that's better than nowt!
    Jon
  5. Forestred
    Forestred Member
    Oct 2, 2003
    297
    +6
    It takes nearly 8 hours to charge mine when one bar on the battery indicator is showing to full via USB. I plug it in at work at about 8:15 and it finishes somewhere around 4pm.
  6. kayzee
    kayzee Member
    Feb 19, 2007
    839
    +31
    Hi guys this thread was the first result from google! I wanna charge my PSP-1000 via USB as have lost the power lead, looks like it can only be done from the 2000 onwards unfortunately.
    If anyone knows different, please post!
  7. Forestred
    Forestred Member
    Oct 2, 2003
    297
    +6
    I have a launch day PSP and as per my previous post I can charge it via USB, the earlier ones have a USB lead that plugs into the computer and on the other end is the mini USB and the charging plug, the PSP doesn't charge via its mini USB socket.
    I got my lead from ebay years ago
  8. Forestred
    Forestred Member
    Oct 2, 2003
    297
    +6
  9. rewari007
    rewari007 Member
    Feb 7, 2010
    You can get loads of psp cables for all purposes on focalprice.com :lease:.. but remember it will take ages for them to deliver.
  10. imranmaz
    imranmaz Member
    Mar 26, 2008
    20
    3
    just get a wall charger... so much faster!
