How do i play avi file on my Sony W series bravia
Discussion in 'LCD & LED LCD TVs' started by mattyboy199, Sep 26, 2009.
  1. mattyboy199
    mattyboy199 Member
    Jan 16, 2005
    156
    As above just purchased a 32W5500 however it seems to only recognise the mpeg format, how can i play AVi's ?
    Matt
  2. reddwarf2002
    reddwarf2002 Member
    Nov 29, 2007
    283
    +22
    Doesn't play avi files! You'll need to convert them to MPEG1.
  3. mattyboy199
    mattyboy199 Member
    Jan 16, 2005
    156
    i see converting the file format will this affect the quaility as it already is ? also will the file size change ?
  4. reddwarf2002
    reddwarf2002 Member
    Nov 29, 2007
    283
    +22
    File size will definitely be a little bigger. You can keep the original quality by specifying when re-encoding.
  5. mattyboy199
    mattyboy199 Member
    Jan 16, 2005
    156
    dont suppose you know of any free software that can do this ?
  6. reddwarf2002
    reddwarf2002 Member
    Nov 29, 2007
    283
    +22
    Sorry I don't know. Try Googling for media converter.
  7. pappus
    pappus Guest
    AVI is a container format. Your video inside might actually be MPEG 1 or 2 already. In that case you could find a tool to change the container format into something your Sony accepts (e.g. .mpg or .vob) without re-encoding the video and hence no quality loss.
    Try
    Tools - Video software and downloads - VideoHelp.com
    for free tools.
  8. mattyboy199
    mattyboy199 Member
    Jan 16, 2005
    156
    Only recently got round to converting a file from AVI to a much poorer quality MPEG1 file format. Was not impressed at all ! i cant believe sony havent updated their firmware to allow a number of different file formats to be used, my external WD media player is 10 times better.
    Should of bought the Samsung !
  9. pappus
    pappus Guest
    Did you try to convert to a MPEG2? I have got a 40W5500 and can play MPEG2 format in perfect quality (e.g. a DVB-S recording or a DVD VOB file). The Sony is only struggling in principle with any MPEG4 format as I think it cannot decode H.264.
  10. mattyboy199
    mattyboy199 Member
    Jan 16, 2005
    156
    i tried MPEG2 1st off as that was recommended however it didnt seem to like it. Will have another go. Could possibly need a firmware update which can be DL from Sony's website (i think a new version is about to be issued as the current link is inactive).
    Why do they make these things so difficult !
  11. mattyboy199
    mattyboy199 Member
    Jan 16, 2005
    156
    been trying to download the firmware update via sony website although it keeps timing out dam it !
