How do I access TG582N
Discussion in 'ISPs & The Internet' started by henry1234, Sep 10, 2012.
  1. henry1234
    henry1234 Member
    Nov 15, 2002
    340
    +8
    I bought a technicolour TG582N off ebay to save a few pounds rather than £40 from plusnet, ready for a new broadband install.
    Today I tried to connect to my router to my mac mini to set it up ready for activation date but I can't access it.
    I have tried
    admin, administrator, Administrator and left password blank or tried the serial number.
    I don't know which ISP the router came from?
    SSID:smarterbroadband
    I have reset the router.
    Can anyone offer any suggestions to access the router settings?
  2. Mr Incredible
    Mr Incredible Well-Known Member
    Dec 2, 2003
    20,936
    171
    +8,527
    Try the serial number as the password?
  3. henry1234
    henry1234 Member
    Nov 15, 2002
    340
    +8
    Thanks but it's not worked.
  4. Mr Incredible
    Dec 2, 2003
    20,936
    171
    +8,527
    Ooops, I realised you'd already tried that! :blush:
    If the serial number has characters, make sure you use the right case. I had to use upper case on my Thomson router on O2.
  5. PowerLee
    PowerLee Member
    Apr 29, 2007
    199
    +24
    You tried;
    SuperUser as the log in name ( note the capital S at start & U in the middle! )
    & then the serial number as the password? make sure you include the 2 letters at the start of the serial number.
    I've got 2 of these but there O2 branded & both serial numbers start with CP
  6. Fe_man2000
    Fe_man2000 Member
    Mar 27, 2005
    1,412
    63
    +179
    very common for this model is
    username - Administrator (capital A)
    pass - default wireless password often printed on the bottom of the router. usually all capitals.
  7. bogart99
    bogart99 Member
    Jan 17, 2007
    579
    +12
    As above often in small type on base of unit. For the password try "password "user will no doubt be "admin". I've had some routers where on the initial setup the password is left blank but you've tried that so give password a go.
