Honda CRV Sat Nav DVD Disc Latest Version?
Discussion in 'ICE, Sat Nav & Dash Cam Forum' started by Del, Jul 11, 2008.
  1. Del
    Del Member
    Nov 15, 2000
    715
    +14
    Hi all
    I've recently purchased a Honda 2005 CRV with a factory fitted Sat Nav without the DVD Nav Disc
    There seems to be confusion amongst the Honda Dealers I've approached with regards to the latest version and compatability:confused: One dealer mentioned v3.23 another stated v2.08
    As these are special order items from the dealers, I'm not prepared to pay approx £200 (non refundable) and get the wrong disc.
    Furthermore no dealer I've approaced so far has the disc in stock to be able to check compatability with the Sat Nav.
    Anyone with a CRV incl satnav please I have the following questions
    1) What's the latest version you're using ?
    2) Where can I get one cheaper than £200 if possible?
    3) Do you know of a Dealer with the DVD in stock please?
    Thank you in advance
    Del:confused:
  2. simon100
    simon100 Member
    Nov 2, 2004
    318
    +13
    The most recent version for the Honda Civic is v3.23. Not sure if it is the same system as the CRV though.
    I found a copy on ebay for £75, a lot cheaper than Honda sell it to you. They were genuine disks as well.
    I would suggest that you contact Honda customer service and ask what disk your system will accept, each new version upgrades the OS, and have a search on ebay.
  3. Crocodile
    Crocodile Well-Known Member
    Nov 4, 2002
    12,711
    +2,606
    You can often buy disks direct from the map data provider for around £75.
    Have a look at TeleAtlas.
  4. Ged
    Ged Member
    Apr 29, 2002
    901
    +19
    I have a CRV; I believe, but please check, that the MK2 CRV uses V2.xx and possibly, later versions use V3.xx
    Our 2003 CRV came with 2.01 and I aquired a 2.06 (I think) of ebay, but the DVD is now in error; the old (2.01) disc is recognized but I will need to reboot to use the 2.01 or buy a new disc.
    Unfortunately, £200 is about right and why (amongst other issues of the CRV sat nav) others buy a cheaper stand alone unit.
    I thought 2.05 was supposed to be OK, don't know of how much map improvements there are in 2.08
    Edit. forced download to older disc/firmware finally worked atfer the usual disc error reading.
    • Thanks Thanks x 1
  5. Davemazo
    Davemazo Member
    May 29, 2005
    688
    +20
    I have a `06 Accord and i`m led to believe that Honda satnav systems with handsfree (introduced from `06) use a satnav disc that starts with 3.XX whereas cars without handsfree use 2.xx discs theres plenty of info on the Honda Accord forum search Google for THAOC or go to http://www.phpbber.com/phpbb/index.php?mforum=sp4rks
    • Thanks Thanks x 1
  6. Member 589421
    Member 589421 Member
    Feb 15, 2012
    Check www.navbackups.com
    They have Europe & North America navigation discs available
