* Home Theater Set Up HELP *
Discussion in 'Home Cinema Buying, Setup & General Help' started by benc007, Oct 25, 2013.
  1. benc007
    benc007 Member
    Apr 7, 2013
    19
    I bought a Tivo Roamio Plus and I connected it directly to my Panasonic Plasma VIERA TC-P60ST60 via HDMI. The problem is that the sound quality from the built-in Panasonic TV speakers are horrible.
    I have a LGDVT418 home theater system (with 4 speakers). I also have an XBox, a Blu Ray player, and a DVD player. What is the best way to set up everything so I can use my LGDVT418 system / speakers?
  2. marty1
    marty1 Member
    Apr 29, 2008
    1,240
    +88
    From what I can tell you do not have hdmi connections on your sound system. If that is the case then it should have an optical lead connection so you connect your Tivo, Xbox and bluray player (depending on how many hdmi connections you have) into the tv. Then have the optical lead going from your tv (optical out) into your sound system. Just make sure your tv volume is off.
    Marty
  3. benc007
    benc007 Member
    Apr 7, 2013
    19
    Hi Marty,
    According to http://www.newegg.com/Product/Product.aspx?Item=N82E16882005025 the LGDVT418 has:
    Video Signal Out
    Composite (Monitor) 1
    Component 1
    S-Video 1
    Component Switch
    Component/S-Video by OSD
    Component/SCART by OSD
    Headphone Jack (3.5mm)
    External FM/MW Antenna
    Which is the "optical lead" going from your tv (optical out) into the LGDVT418 sound system?
    Ben
