Hk 3490 bi-wire speakers & amp connect single wire
Discussion in 'Integrated Amplifiers & Receivers' started by mb0ng0, Dec 14, 2009.
  1. mb0ng0
    mb0ng0 Member
    Aug 7, 2009
    34
    Hi all,
    I did install my 2XKEF IQ50 speakers onto the hk3490 and i do love the sound. I'm not sure about the connection. Because the amp and the speakers can be connect bi-wired.
    I did not connect them bi-wire but single wire because I'm not convinced that this would improve the sound.
    I did connect them like this:
    [​IMG]
    (right mouse open)
    speaker 2, is that when you bi-wire your speakers? Did I do the connection in the right way? or do i have to connect them in a different way?
    I did not found the solution in the manual.
    Thanks in advance
  2. mb0ng0
    mb0ng0 Member
    Aug 7, 2009
    34
    anyone?
  3. dante01
    dante01 Well-Known Member
    Mar 5, 2009
    25,829
    +4,557
    Your current connections look correct. You'd probably not benefit from bi-wiring the speakers anyway? The B terminals are simply split from the same amplification source within the amp that powers the A terminals. All you'd be effectively doing is bridging the power at the amp rather than bridging it on the speakers as you are currently doing. Bi-wiring is only of any practical use if used in conjunction with bi-amping. Bi-amping would provided independent power to the hi and low frequency drivers rather than shared power from the same source.
    • Thanks Thanks x 1
  4. mb0ng0
    mb0ng0 Member
    Aug 7, 2009
    34
    Thanks! Im glad i did it in the right way.
    The sound is superb!
    regards,
