Help with setup 7.1
Discussion in 'Speakers' started by Ziade2006, Feb 22, 2012.
  1. Ziade2006
    Ziade2006 Member
    Oct 15, 2011
    357
    +25
    Hi guys i have the following speakers, i am new to HT and would like to get your advice:
    Actual Setup:
    Centre Ms304
    Fronts Ms 902i
    Surrounds Ms 902
    Back Speakers Ms 902i
    Sub Gale Storm
    Amp: Sony STRDH 800
    Do the speakers match my amplifier?
    Do any of them need to be replaced?
    Use Movies 60%, Music 20% (Mostly trance), Games 20%
    Thanks for your help.
  2. PSM1
    PSM1 Well-Known Member
    Dec 20, 2008
    18,226
    171
    +2,903
    Morduant short speakers are often not recommended for bright sounding amps like Sony but as long as it sounds OK to you then it does not really matter what is or os not recommended.
    Do you feel anything is missing or wrong with your system? If you are to upgrade anything what budget would you have?
  3. Ziade2006
    Ziade2006 Member
    Oct 15, 2011
    357
    +25
    They are good in my opinion but i never had good speakers and i am no audiophile, so what sounds good to me may be very poor to someone else. The amps and speakers were all bought on here recently and i cannot change all of them but if for example if the centre is not good in my setup i can change it. I don't know if the 902i can be used for surrounds or back speakers
  4. PSM1
    Dec 20, 2008
    18,226
    171
    +2,903
    As long as it sounds good to you then just sit back and enjoy.
  5. adg243
    adg243 Member
    Nov 9, 2011
    15
    In this hobby, when deciding, what matters the most is your judgment and ears :)
    Adam
  6. jason1wood
    jason1wood Member
    Feb 5, 2006
    2,342
    +134
    Or what the missus says! :)
  7. adg243
    adg243 Member
    Nov 9, 2011
    15
    The wisest of men hath spoken :)
