Help TV Stuck on Standby
Discussion in 'LCD & LED LCD TVs' started by NightWing2099, Dec 24, 2013.
  1. NightWing2099
    NightWing2099 Member
    Jan 30, 2013
    16
    I have a Grundig GULCD37HDIT, and suddenly its stucks on the Standby, the light dims if you press power switch. Is there an easy fix.
  2. JayCee
    JayCee Active Member
    Jan 20, 2004
    15,749
    +1,576
    It's probably a fault in the power supply...as to whether it's an easy/cheap fix that depends on how skilled you are at fault-finding and diagnosis.
