Help! Tritton AX Pro's won't turn on.
Discussion in 'Headphones & Portable Music' started by J3llym0nst3r, Apr 3, 2010.
  1. J3llym0nst3r
    J3llym0nst3r Member
    Apr 3, 2010
    22
    I recently purchased a set of Tritton AX Pro's from America to use in the UK. The power supply said it uses:
    Input: 100-240VAC 50/60Hz 0.2A
    Output: 9VDC 0.5A 6W MAX
    So I figured I could just use a US to UK plug adapter. However it doesn't turn on. I'm not sure if it's just a dodgy adapter of I this isn't going to work. Anyone got any ideas?
    JM
    p.s. I believe they are the latest model, with one power source for headphones and the block.
  2. sdb123
    sdb123 Well-Known Member
    May 17, 2005
    18,474
    +2,239
    Do you have an adapter or a proper transformer? If the former, try the latter. :smashin:
  3. J3llym0nst3r
    J3llym0nst3r Member
    Apr 3, 2010
    22
    Just an adapter, do you think I need a transformer?
  4. sdb123
    May 17, 2005
    18,474
    +2,239
    For US devices I have always used a transformer, giving the correct voltage and is safer than an adapter. Check places such as Maplins for a suitable product.
  5. J3llym0nst3r
    J3llym0nst3r Member
    Apr 3, 2010
    22
    Just got a transformer from maplins. It still does not turn on. Do you think this could be a faulty product?
