Help, My teeth are falling out
Discussion in 'General Chat Forum' started by danmc_82, Feb 11, 2009.
  1. danmc_82
    danmc_82 Active Member
    Jan 19, 2007
    4,364
    +543
    Bad teeth run in my family (my mums side). Im 26 and my teeth are crumbleing away. Just ten minutes ago I ate some toast and half of one of my back teeth came away :eek:
    My dentist is private and also expensive. What are my options to have my whole mouth re-done. Are veeners the way to go or just some false teeth like im 80 years old.
    Any help will be appreciated
  2. Iccz
    Iccz Active Member
    Apr 29, 2008
    24,173
    +6,763
    You need to be asking your dentist, you should be able to phone your practice up and talk to the assistant who might have some idea, I have weak teeth too due to too much flouride... never eat toothpaste... and have had a couple of teeth damaged but nothing too serious yet thankfully, the dentist just filed down the roughness and left it as it is, said there's no point in doing anything until it becomes a problem or looks like it's going to become a problem.
    Speak with your dentist and see what they say, generally they will give you the best advice :thumbsup:
    • Thanks Thanks x 1
  3. eric pisch
    eric pisch Active Member
    Dec 28, 2006
    7,478
    +764
    stop taking drugs / eating sweeties :p
    brush your teeth and gums with a braun oral B electric toothbrush for at least 2 mins twice a day and synsodyne F toothpaste (i switched to this and it stopped mine breaking up)
    go see a different dentist
    • Thanks Thanks x 1
  4. Iccz
    Iccz Active Member
    Apr 29, 2008
    24,173
    +6,763
    Sadly drugs / sweets aren't the cause for all dental problems, mine for example are because of high levels of flouride in the stages of tooth development. It can also be a genetic thing as OP has said his family have problems.
    An electric toothbrush is not always recommended for people with such problems, a dentist might recommend you a soft bristle manual brush where you have more control over the cleaning, electric brushes are not necessarily best for everyone, there are a number of things to consider, strenght of teeth and gums being quite important, you can do more damage than good if you're not doing it correctly.
    A dentist will know what kind of brush is best suited to your teeth and gums, especially if you have problems with your teeth. I use a medium and a soft bristle brush for my mouth along with regular flossing and mouthwash.
  5. danmc_82
    Jan 19, 2007
    4,364
    +543
    Ill try :D
    Think its to late for that
  6. danmc_82
    Jan 19, 2007
    4,364
    +543
    Thanks Iccz, Ill give them a phone and see what they say. I hope they do a sort of payment plan, not going to be able to affort £1k's of treatment.
  7. eric pisch
    Dec 28, 2006
    7,478
    +764
    you do rebuild enamel slowly, alot of my damage was down to drinking pints of fruit juice and using a very hard brush, dentist told me to get the oral b as its very soft
  8. Iccz
    Iccz Active Member
    Apr 29, 2008
    24,173
    +6,763
    The Sensodyne Pronamel toothpaste is great, but it's not cheap :thumbsup:
  9. Ned Senior
    Ned Senior Active Member
    Aug 14, 2006
    3,457
    +308
    Mine rotted through too much lemonade drinking dentist said there is lots of acid in lemo and it is not so much the sugar... haven't had lemo since before xmas and no problems further..
    PS I am immune to local anaesthetic so imagine the pain whilst they drill!!! Yikes
    In future I will goto the local dental hospital I feel for general anaesthetic
    I was ok until recently too dunno what they have changed or if it is me!!!!
  10. Iccz
    Iccz Active Member
    Apr 29, 2008
    24,173
    +6,763
    Luckily for me I have a really good dentist... I have a fear of hospitals and doctors etc... but i'm fine with the dentist, but if the time ever comes where I need an injection i'll be spun into a panic attack, not going to be fun that... oh dear, hopefully it'll never come to that though!
    Acid is a lot worse than sugar, I find that chewing sugar free gum during the day helps keep my mouth feeling a lot better, and im sure it helps combat the acidity of food/drinks.
  11. CraigofScotland
    CraigofScotland Active Member
    Jan 13, 2009
    4,649
    +521
    Seek medical advice . .
    if you need tv advice this is the place. .
    if u need teeth advice visit the dentist
  12. Ned Senior
    Aug 14, 2006
    3,457
    +308
    Does this mean I should seek a prozzies advice:D
    Enter Iccz....
  13. 27neth
    27neth Active Member
    Feb 15, 2007
    2,409
    83
    +378
    I know the dentist isnt cheap :D My girlfriend had to get 12 crowns done (she ground her teeth down in her sleep)
    She got told either false teeth or the crowns (£3500) i had to pay half :mad: but i would of picked the same choice if it was my teeth. They do look really good too.
    John.
    • Thanks Thanks x 1
  14. Iccz
    Iccz Active Member
    Apr 29, 2008
    24,173
    +6,763
    Are you trying to say i'm a... :eek:
  15. Ned Senior
    Aug 14, 2006
    3,457
    +308
    Nah just a trusted advisor mate :)
    • Thanks Thanks x 1
  16. Iccz
    Iccz Active Member
    Apr 29, 2008
    24,173
    +6,763
    good recovery :smashin:
  17. Ned Senior
    Aug 14, 2006
    3,457
    +308
    :D
  18. nwgarratt
    nwgarratt Well-Known Member
    May 5, 2002
    23,573
    +2,289
    I have a famlily with all bad teeth. I will be always grateful thay my parernts paid for something called fisher treatment. I was about 8 when the Dentist put this special covering over my teeth to protect them from decay. It tasted bloody awful when he did it. I am not sure how long it lasted as it would have stopped working a long time ago, but I am now nearly 35 and still have all my teeth and not one filling.
    I have always preferred using a electruc toothbrush and use one of the Oral B Vitality ones.
    Haven't been to the Dentist in yearss, I am not sure if I am registered anymore.
    • Thanks Thanks x 1
  19. Kevo
    Kevo Active Member
    Aug 23, 2001
    5,218
    83
    +117
    I have the 'teeth falling out/crumbling' dream quite often. (that along with running through the streets naked :eek: )
    I feel for you guys.
    • Thanks Thanks x 1
  20. Bilbob
    Bilbob Active Member
    Feb 21, 2005
    4,399
    103
    +295
    Not being funny, but why not go NHS for it? Dentists are not as hard to find as they used to be, and the cost is capped, I think the upper limit is about 400 odd quid for a full course of treatment, and yes, they will give you crowns if the dentist deems it suitable. For a guy of 26, I would think he would consider it suitable!
    • Thanks Thanks x 1
  21. DVD-Man
    DVD-Man Active Member
    Jul 24, 2004
    6,321
    +785
    For anyone reading, not the OP who is getting a lot of dental bills, like the few guys here who recommended the Oral B Electric Toothbrush, I'll add another recommendation!
    I've had them for 10 years now and I've only had maybe 4 or 5 fillings in that time, I just got a new 8500 pro care for Xmas as my previous brush just seemed to not hold a charge for that long but getting 5 years out of a brush that can cost as little as £15 is ace, I've progressively upgraded mines though thus going from £15 to £60+.
    To the OP, I'd ask about false teeth, they don't look as bad as they used too but many prefer caps etc as my Mum said you lose 'taste' by getting false teeth, it's hard to explain but she said you can sort of taste stuff via your teeth as well as your mouth, this might take some getting used too.
    Please don't let them get diseased though as it could lead to a lot of pain and suffering and possible hospital treatment.
    Good luck
    Liam
    • Thanks Thanks x 1
  22. danmc_82
    Jan 19, 2007
    4,364
    +543
    I thought it was impossible to get an NHS denstist.
  23. pandemic
    pandemic Active Member
    Dec 28, 2008
    3,045
    +347
    Ok you don't need a bleeding electric toothbrush lol. I've always used a regular tooth brush and had zero fillings and zero cavities in 24 years.
    Just to add if the enamel on you teeth is weak, your dentist should be able to apply a temporary coating (tastes like banana) which strengthens the enamel. not sure how long it lasts though.
  24. Bilbob
    Feb 21, 2005
    4,399
    103
    +295
    Not at all, it might be harder in some areas of the country, but AFAIK, if you NEED one, you will find one. Ring your local NHS trust and ask them for advice, or even look on t'interweb. For Manchester as an example, ( I was looking myself recently!) you can ring the trust and they give you numbers... MIght have to try a few like I said, but you will be able to find one if you need it.
    EDIT: In fact, click here for NHS dentists...
    Clickt he toothy icon, enter your postcode and click search...
    • Thanks Thanks x 1
  25. danmc_82
    Jan 19, 2007
    4,364
    +543
    Thanks alot :thumbsup:
  26. Bilbob
    Feb 21, 2005
    4,399
    103
    +295
    yer very welcome my gummy pal :rotfl::smashin:
  27. MrFurious
    MrFurious Active Member
    Sep 9, 2000
    12,870
    +825
    ive smashed the hell out of my teeth this past few months, im having fits in my sleep that consist of me grinding my teeth and clamping my teeth, i dont know how they have not snapped yet, the front two are ground quite bad, problem is that i lost my job and can no way afford the dental fee's
  28. danmc_82
    Jan 19, 2007
    4,364
    +543
    :D At least my grin has teeth
  29. jendo
    jendo Member
    Feb 9, 2006
    648
    46
    +141
    Cant you get free dental care if you are unemployed?
  30. Naqv
    Naqv Active Member
    Oct 15, 2006
    3,103
    +206
    yes.
