HELP! I have a Back/Previous button in middle of screen
Discussion in 'Computer Software & Operating Systems' started by irvin38a, Oct 23, 2009.
  1. irvin38a
    irvin38a Member
    Nov 11, 2007
    235
    +30
    I have upgraded from Vista and now for some reason have a Back and Previous button stuck in the middle of my screen!! Anybody know how to get rid??
    Oh and I also have a ''test mode windows 7 build 7600' message in the bottom corner. Anyone??
    Its a retail version btw.
  2. Scainer
    Scainer Member
    Jan 23, 2009
    215
    +23
    I assume its not activated yet
  3. EmotionalTrout
    EmotionalTrout Member
    Nov 29, 2006
    666
    +74
    Try this in cmd as administrator
    bcdedit.exe -set loadoptions ENABLE_INTEGRITY_CHECKS
    bcdedit.exe -set TESTSIGNING OFF
    Let me know how you get on.
  4. irvin38a
    irvin38a Member
    Nov 11, 2007
    235
    +30
    The boot configuration data store could not be opened
    Access is denied
  5. irvin38a
    irvin38a Member
    Nov 11, 2007
    235
    +30
    Ah, the reg key just hadn't been sent yet!! :suicide:
    The BACK/PREVIOUS buttons are still there though!!! They were gone after reboot but 10 mins later they have re-appeared!!
    If you put the cursor over them or click on them etc nothing happens. HELP!!!
  6. bodhimoosa
    bodhimoosa Member
    Nov 17, 2009
    I have the same issue with the button and I have no idea how to get it off. any help?
  7. Vanthojo
    Vanthojo Member
    Dec 22, 2009
    Go to your Task manager, find the process apvfb.exe and terminate it. Presto, buttons disappear. Should be down-hill from there. Probably need updated (VAIO) pointing device drivers. Good luck with Sony support services ;-)
