Headphones for use with HD channel on my TV
Discussion in 'Headphones & Portable Music' started by lindos, Feb 8, 2012.
  1. lindos
    lindos Member
    Sep 19, 2010
    as i am slightly hard of hearing i use a set of wireless headphones when viewing tv and watching videos. the problem is they will not work when viewing the HD channels also when viewing some of the newer films i have the same problem. Do i need better headphones to be able to listen in HD ?
    Hope someone can help.
    cheers Les.
  2. Phildick
    Phildick Member
    Jun 7, 2010
    428
    28
    +32
    Do you have the base unit plugged into the headphone socket on the TV?
    When you say they do not work on the HD channels what do you mean? Is there no sound at all?
    What make and model is the TV?
  3. lindos
    lindos Member
    Sep 19, 2010
    thanks for your quick reply phildick.I think i have solved the problem,I have bought a headphone adapter and am now able to plug directly into my onkya base unit instead of the tv and up to now it seems ok.
    thanks again for your reply, heres to happy listening cheers Les.
