HDMI to Scart
Discussion in 'HDMI Cables & Switches' started by roasty, Jan 6, 2006.
  1. roasty
    roasty Guest
    I currently have a fairly old tv that has no HDMI socket nor Component Video.
    Doubt the answer is yes, but can you buy a lead that connects the hdmi from the DVD to the scart socket on the TV to increase PQ?
    I know you can buy Component Video to scart, or am i mistaken?
    if not mistaken, is this better than just using RGB?
    many thanks
    Keith
  2. loadsofleads
    loadsofleads Guest
    Hi, you can't use HDMI with a scart socket because HDMI carries ONLY a digital signal and scart carries ONLY an analogue signal. There is such a thing as a Component to scart cable which carry a Y/Cb/Cr signal but the scart socket would have to accept that signal. Not many do.:thumbsup:
  3. roasty
    roasty Guest
    thanks
    how will i tell if the scart can accept the signal Y/Cb/Cr?
  4. loadsofleads
    loadsofleads Guest
    Have a look in the manual and see what signals the scart will accept, look out for 'component', Y/Cb/Cr, Y/U/V or Y/Pr/Pb
  5. roasty
    roasty Guest
    cheers, looked at my manual, only Y/C so doesnt look like my TV will, nevermind, just means that now have to buy a new TV
    keith
  6. hornydragon
    hornydragon Active Member
    Dec 19, 2001
    28,302
    +1,412
    Thats the digital flavour of Y Pb Pr IIRC so wont be available on analogue connections
