Half Life On Vista
Discussion in 'PC Gaming Forum' started by Dextur, Aug 8, 2007.
  1. Dextur
    Dextur Active Member
    Aug 30, 2004
    9,031
    +1,303
    Anybody tried running HL on Vista ?
    Friend is trying to run it now but which ever option she choses from the graphics menu, Software , Open GL or Hardware, she ends up getting a really appaling look to the game, very blocky etc.
    I can't test it at my place as I have XP, but wondered if anybody has had the problem and knows how to fix it ?
    I will just direct her to this thread if anybody has an easy fix.
    Thx
    Simon
  2. Rasczak
    Rasczak Active Member
    Apr 3, 2002
    18,668
    +1,098
    I have Half Life installed within Steam and have no problems running it on Vista Home Premium 32 Bit. I started in software and it ran fine. Changed the settings to OpenGL and again it ran without problem.
    Perhaps the problem could be the graphics driver? Perhaps look for the latest drivers for whatever card you have? Secondly is your friend playing from the disc or has she downloaded Steam and is playing though that. The latter option is the better because you'll get the latest version of the game suited to the OS.
    To get Steam goto the website at Steam Powered.
  3. Dextur
    Aug 30, 2004
    9,031
    +1,303
    She's just trying to play it from a CD not Steam no, but whenever she choses any of those options it looks appaling. It's so cheap now on Steam, I have advised her to take a look at just downloading HL and HL2 directly from there.
    Thanks anyway for the tip for letting me know.
    If you have two spare mins, I dont' suppose you could do a screen shot of the very first screen you see on HL when you load a new game could you?
    Your in a carriage with some metal sliding doors in front of you, just want to see what it should look like working correctly.
    I believe she does have the latest video driver yes, but will double check.
  4. Rasczak
    Apr 3, 2002
    18,668
    +1,098
    It shouldn't cost anything - there is no need to rebuy it. Download Steam, goto the 'My Games' tab and select 'Activate a product on Steam...' and enter the key. Your copy of HL will then be tied to Steam (as well as enabling you to download all the free addons that accompany that classic game (TFC for example).
  5. Razor
    Razor Well-Known Member
    Dec 15, 2004
    36,648
    +8,743
    I run Half Life 2 on vista with no problems at all. :)
    Do as Rasczak says and connect to steam, this will update your copy of Half Life 2 to the latest version automatically.
    What res have you got the game running at? What spec is the pc?
  6. Dextur
    Aug 30, 2004
    9,031
    +1,303
    PC is pretty decent, she's choosing the max res available in the graphics setup, was pretty low tbh, but the max available there.
    I'll direct her to this thread for the suggestions.
    Cheers again.
  7. Rasczak
    Apr 3, 2002
    18,668
    +1,098
    Is she using a widescreen monitor? If so has the 'widescreen' option been set? That could, I suppose, make things look blocky.
  8. Dextur
    Aug 30, 2004
    9,031
    +1,303
    Not in front of that PC, will need to ask her , I was there when we were trying it out can't say I saw a widescreen option, but tbh it was definatley more of a "CGA" type look, reminded me of looking at an old Quake game before GFX cards :p
    I've sent her an email with a link to this thread so she can take a look at the advice.
    Thx again.
  9. Rasczak
    Apr 3, 2002
    18,668
    +1,098
    If you go down the Steam route you might find more resolutions are supported. The Steam interface gives alot more options than you get with the DVD version of the game.
  10. God's Toy
    God's Toy Member
    May 28, 2005
    158
    +12
    Using Vista Ultimate 32 and Half Life on steam here and it's fine, Is the game fully updated? If she loads it up on Steam she can auto update to the newest patch.
  11. Knyght_byte
    Knyght_byte Member
    Nov 4, 2004
    11,035
    +671
    i had HL2 running fine on Vista 64bit using steam.....looked gorgeous :D
    that HDD isnt in the machine atm tho so i cant do a screenie, sorry...
  12. Tommy Angelo
    Tommy Angelo Guest
    Simon, it might be best for her to take a screen shot or to take a picture of the screen so we can get an idea of the problem.
  13. God's Toy
    God's Toy Member
    May 28, 2005
    158
    +12
  14. Dextur
    Aug 30, 2004
    9,031
    +1,303
    Thanks all, in the end she got the download from Steam and all is working perfectly, it looks great. Thx for all your help.
  15. Indiana Jones
    Indiana Jones Moderator
    Nov 4, 2003
    23,534
    +2,327
    I have the game running fine and it looks great but if I save the game then exit and then reload the save it wont run, it just comes up saying something about the A.I. being disabled :(
  16. Razor
    Dec 15, 2004
    36,648
    +8,743
    Strange. I havent had this at all? :confused:
  17. Tommy Angelo
    Tommy Angelo Guest
    Type "half life AI disabled" without quotation marks into google.
  18. Indiana Jones
    Nov 4, 2003
    23,534
    +2,327
    Did exactly that after I posted and have since downloaded a different config file which has fixed the problem.
  19. Chaos
    Chaos Moderator
    Aug 31, 2007
    2,932
    +285
    I got this game recently as it's one of the classic games I've been meaning to try for ages. £15 for this and episode one from Steam. I haven't felt this way about a game for so long. It's amazing.
  20. Dextur
    Aug 30, 2004
    9,031
    +1,303
    Truly a classic game, for me personally I had vastly more fun with HL1 than HL2, but both should be on everybodies play list. Sheer quality.
  21. Rasczak
    Apr 3, 2002
    18,668
    +1,098
    I think Valve made a mistake moving the Half Life series to 'episodic gaming'. Half Life and Half Life 2 were both classics - but Half Life 2:Episode 1, aside from having a long and bloated name, is so short it is forgetable.
  22. Razor
    Dec 15, 2004
    36,648
    +8,743
    They were meant to be releasing a new episode every few months along with Sin. As we can all see this never happened. Shame :thumbsdow
  23. Tejstar
    Tejstar Member
    Dec 4, 2002
    22,289
    +1,012
    Which is one of the main reasons I'm waiting for Episode Two, so that I can play both one and two back-to-back.
  24. undeadboll
    undeadboll Member
    Jan 21, 2009
    mine runs but text is messed up
