Nice Monkey
Established Member
Guide on which brand media player to select
This for playing local content including native DVD/BD/UHD in ISO or Folders with or without their respective menus.
Regarding Video format support and Picture Quality including DV and HDR10+ all mentioned media player models are good and offer basically the same. For Music they all play Stereo/MCH PCM formats in High Definition, DVD-CD and SACD Stereo/MCH (with DSD => PCM conversion).
MovieWall features and Music Players on the other hand vary a lot per brand.
No Egreat did not stop as they still release both new HW models and FW (Chinese and English languages only) but seem to concentrate on the internal Chinese market these days (included for comparison only for those knowing them).
Dune is an above average stable and universal media player doing everything pretty well. The most hazzlefree all-around media player I found thus far and I have seen plenty of them. My Egreat players (no DV or HDR10+ on these) do get close and Zidoo clearly approaching as they are very active on FW improvements. The MovieWall has been improved a lot with their NewGUI FW and Dune is definitely catching up here with the current competition. Their Music Player sounds well but is still a real barebone as basic as possible player.
If you value many advanced Video player features in general, a decent but still in full development Music Player and excellent Library & Movie Wall features too then get yourself a Zidoo. It is also compatible with several external Server Library services like ROON, Jellyfin, Plex and upcoming JRiver. For me it is gradually becoming the Swiss Army Knife among media players.
If you want perfect BD/DVD Menu playback/processing from ISO/Folder a Dune is now virtual identical to a real disc player similar to my OPPO playing menus smooth as silk too. My older Egreat on the other hand was fluent also but has still problems with some BD menus scoring below Dune on that. Zidoo is following at a considerable distance at the bottom of this list with regular BD/DVD menu problems and is far from playing BD menus fluently (as-is the biggest shortcoming using a Zidoo).
If you want next to Stereo Music also perfect MCH Music from DVD-CD, SACD, DVD-Audio and BD Pure Audio albums then get yourself an OPPO (or equivalent disc player). There are no full alternatives here (yet) but Android players are closing in step by step here too.
Prices from Dune and Zidoo for various base models are very much on par. For specific HiFi models with a quality DAC included the Dune Max/Ultra have a substantial lower price compared with Zidoo Neo S/Alpha models but have a far less functional pront panel. The older UHD3000 is on par here sitting between Max and Ultra.
But what about Zappiti? The main FW looks very much Dune like including the information displayed on the Front Panel. The Zappiti MovieWall follows their own Client/Server model and is of proven quality which may next to their much appraised for sure good-looking GUI be a valid reason to go for a Zappiti taken the premium price to be paid for granted.
A recent new tiny player is the big exception here: "Dune HD Homatics Box R 4k Plus".
The unique thing it has certifications for Andoid TV and most streaming services including Netflix. Also unique it can convert MCH DD/DTS to MCH PCM, has AV1 and is HDMI 2.1 compliant. But it does not support HD audio in PCM or DTS as these will be downgraded. Also the AQ via HDMI is the lowest I have experienced with any media player. It is a good player combining many advanced unique features but not for those thrilled with top quality for movies and above all music. Recommended for use in combination with just a dumb TV/Projector or a TV plus a soundbar.
Another review was done for the Eversolo DMP-A6 dedicated music streamer.
I regard this the (almost) perfect music streamer at an affordable price. It you are in the market for external (paid) streaming services combined with also combined external (paid) library services then you should for sure have a look at it. It may do miracles for you.
You might end up with more than one choice finally as I did myself.
About Android OS versions and their peculiarities:
This is highly relevant to understand the differences and problems encountered when installing APP's via either the Google Play Store or directly running installation APK's.
Many customers think there is only one Android existing and used universally for everything. As a consequence they expect all Android APP's to run on any platform which they for sure won't.
Android OS versions
There are 3 different Android versions playing a role here. Knowing with which version one is dealing is far from trivial.
Android (standard Android)
It is just called Android running on Smartphones and Tablets
This is the most used Android OS version and referred to by me as "standard Android".
The appearance changes with each OS generation slightly adding new features but appearance will vary mostly due to manufacturers/brands mostly using their own overlay on top of it.
Android TV
This is labeled as such and indicated on selected platforms with the "Powered by Android" logo. Only that version is really designed by Google directly for big screens. Android TV or (ATV) must be licensed to be used and may not be altered or customized on a platform to get certified by Google. This warrants stability and compatibility in a high degree.
Using the Google Play Store one will get to see and next get access only to applications specifically designed for Android TV. Some applications exist in both standard Android and Android TV versions to run optimized on mentioned different platforms. Above all APPs for streaming services are mostly made available in both versions.
ATV comes with its own integral application Launcher/GUI which is really nice and easy to be recognized. Specifically the Launcher/Menu coming with ATV8 and above OS versions is very easy to recognize. it can also be controlled by voice command with remotes including a microphone.
Android Leanback
But omitting Leanback to be mentioned anywhere causing a big confusing for users and applications to be the standard Android OS version.
This is a modified/patched standard Android kernel for Media Players. It is e.g. patched to be controlled by IR remotes, have HDD's attached via SATA or USB and use the Wired Ethernet. Also the screen aspect ratio is typically forced to use Landscape instead of configurable/automatic Portrait plus Landscape on standard Android.
Manufacturers using modified Leanback seem to be free to use the Android core without licences (remember that is originally a mere Linux kernel).
The Android application menu will vary completely with each implementation and may include various options to customize it or not.
Android OS peculiarities
Almost all media players use Android Leanback but some come with Android TV. Using this Leanback Android OS stupid/strange things can happen: Dynamic contrast option for phones, getting settings for battery saving, Notification Bar peculiarities, APP's insisting to use WiFi as they think a Wired=Mobile Network, inconvenient keyboard pop-ups, problems with access to Google Application Services and/or the Google Play Store, SDHC optional Internal Storage formatting, limited/bad HDMI-CEC implementation etc etc. IR remote controls often work only partially with installed APP's which often can be improved adding a real pointer-mouse via RF or BT operation to simulate touch screen operations including swiping.
Using different brand media players one will see that the Leanback modification/patching is different with each implementation with varying results for what works or doesn't. Occasionally additional Custom Patching (facilitated by knowledgeable customers) improves compatibility for certain aspects.
The Android Leanback OS implementation typically comes with the SDK (Software Development Kit) of the SOC providers (AMlogic, Realtek, HiSilicon etc) not from the media player manufacturer. The Android OS upgrade policy hence also comes from the SOC manufacturer! Realtek thus far never upgraded their Leanback OS versions on any of their SOC's once being released (RTD1195=A4, RTD1295=A6, RTD1296=A7, RTD1395=A7, RTD1619=A9). An exception is Hisillicon which moved from A5 to A7 for e.g. Himedia and Egreat media players. It is not media player brand or any other SOC implementer deciding that! For integrated media player FW the Android OS version and generation hardly matters but for App's added manually it for sure makes a big difference.
- MCH in PCM/FLAC and SACD DSD =>PCM is supported after FW upgrades but lack gapless playback by all brands. You can easily convert albums to a single track with CUE sheets generated as a bypass though. A real must doing so for live albums.
- Only the recent Zidoo Neo Alpha got native DSD 2CH/MCH output on the secondary HDMI Audio/DSD port. This being unique for any Android based media player.
- 2CH Native DSD is supported on specific HiFi models from all brands using an additional HIFi DAC coupled to analog RCA/XLR outputs. DAC quality ranging from good to top quality depending on the model.
- No DVD-Audio album support for playing essential MLP tracks in High Definition audio with any brand yet! Only the DVD-Video compatible DD/DTS tracks on those may work using the video player.
- BD Pure Audio and BD Concert albums are standard supported via the video player. Zidoo specifically may occasionally suffer from BD Menu troubles playing these.
Review and need-to-know Eversolo DMP-A6 streamer
Intro: It will next be ported to a few well know Audio/Video forums and probably Futeko. At the moment I am above all in dialog with Zidoo/Eversolo to...
forum.zidoo.tv
Android OS versions
Android TV
Android Leanback
