Good Earphones For Sound Isolation?
Discussion in 'Headphones & Portable Music' started by Timmer49, Feb 10, 2012.
  1. Timmer49
    Timmer49 New Member
    Dec 27, 2011
    502
    +17
    I bought some Soundmagic E10 earphones. The sound quality for the price range is actually excellent but the sound isolation is next to nothing.
    I am looking to get something else. I don't mind spending a little more, maybe around £50. Sound isolation is the priority, sound quality only second.
    Can anyone recommend some for me?
  2. jamung
    jamung Member
    Oct 24, 2011
    233
    28
    +28
    Have you considered Klipsch Image S4? A bit over your budget though. :)
  3. Timmer49
    Timmer49 New Member
    Dec 27, 2011
    502
    +17
    The S4 have a SNR rating of 16db. Even the E10s were classified as having 18db and they are rubbish. I'm after better SNR not worse.
  4. Steven
    Steven Senior Moderator
    Feb 1, 2005
    35,867
    +5,465
    IEM isolate in conjunction with music playback. My Westone UM2 noise isolation is rated at 25db but that still only muffles environmental noise. Only by playing music I am then sealed from the outside world
    A lot of it has to do with fitting too. How are you getting on with the standardised sized tips? I could never get it quite right until I upgraded and discovered foamies (comply). If you find the same then it you may not find an answer from a sideways step, whereas if the fit is fine then perhaps you just need to rest the water with an alternative
  5. HiFi Headphones
    HiFi Headphones Member Assured Advertiser
    Mar 18, 2008
    536
    +82
    The best way to guarantee good sound isolation is with Comply Foam tips. These heat reactive foam tips solve the problem of fit, comfort and sound isolation for nearly everyone.
