Gigabyte boards & win7 incompatability issues
Discussion in 'Motherboards & Processors' started by snooper, Apr 22, 2010.
  1. snooper
    snooper Member
    Oct 2, 2005
    954
    28
    +68
    Got a prob with with new build crashing and BSOD and have read on a few sites a possible issue with some gig boards & win 7 causing kernel-power prob. Anyone have any knowledge or can enlighten me more.
  2. namuk
    namuk Well-Known Member
    Oct 23, 2006
    21,589
    +4,010
    What model is the Board ?
  3. snooper
    snooper Member
    Oct 2, 2005
    954
    28
    +68
    It is one of the latest Gig boards GA-785GMT-USB3 mATX
  4. namuk
    Oct 23, 2006
    21,589
    +4,010
    Can not see that being an issue Being incompatible with Win7.
    • Thanks Thanks x 1
  5. snooper
    snooper Member
    Oct 2, 2005
    954
    28
    +68
    Would you update the bios to the latest version if it isn't already. Ta
  6. namuk
    Oct 23, 2006
    21,589
    +4,010
    One of the first things i do when i get a new Board, i did this other week to the Ud7.
  7. ninja 12
    ninja 12 Member
    Mar 13, 2009
    549
    46
    +243
    No issues to report here.
    Win 7 x64 and using a GA-MA780G-UD3H , although , I didn't install any of the drivers from the Gigabyte site or disk. I let windows install it's own :D
  8. BrutalUK
    BrutalUK Member
    Nov 16, 2007
    126
    +8
    I've had many Gigabyte boards and my current AMD m/b with win7 ultimate works 100%. Only thing I have noticed with them is they can be fussy about memory, as in the manufacturer.
  9. stephaniecowel
    stephaniecowel Member
    Jul 7, 2010
    5
    Gigabyte fairly frequently release new BIOS' if required. Also because almost all of their MoBo's use dual-BIOS, unlike other manufacturers, it's not really risky flashing your BIOS with Gigabyte. If it goes wrong the system simply reprograms the BIOS from the second chip.
  10. marty2005
    marty2005 Active Member
    Jul 22, 2005
    3,692
    +175
    I have a Gigabyte board and run Win7 but have an Intel CPU. No problems there.
    Problems with AMD may be that you need to get the AMD cpu optimizer driver. Not sure if it's still relevant. It was with dual core.
  11. HeX00
    HeX00 Member
    Nov 14, 2007
    30
    11
    +6
    Nah don't need that optimised driver any more, haven't for a long time :)
  12. gameplanstan
    gameplanstan Member
    Jul 13, 2010
    264
    +12
    I have a ud7 x58/ ud7 p55/ ud6 p55 all work flawless with windows 7. your issue could be hd related.? you really need to give more detailed info on the problem list pc specs etc.
  13. ICPC
    ICPC New Member
    Jul 15, 2010
    112
    +3
    Can't hurt updating to the latest bios as Gig boards are easy to do so on.
    But BSOD is going to be component based. Check all your bits from RAM to HD etc. Check the clocks in the BIOS are not all over the place.
    Gigabyte couldn't exist as a compnay if their boards didn't work with a certain OS.
  14. tvmcp
    tvmcp Member
    Oct 2, 2009
    1,111
    +150
    I've done a Win7 32 and 64 Bit install on two of these boards - no issues at all.
    Try changing the optical drive to ahci if not set already.
  15. snooper
    snooper Member
    Oct 2, 2005
    954
    28
    +68
    In the end it turned out to be a faulty stick of OCZ ram which was causing the prob so after faffing around before the fault was found and then sending it to Holland its sorted now along with a BIOS update and touch wood its running like a dream tbh. Thanks for all the replies/suggestions.
  16. namuk
    Oct 23, 2006
    21,589
    +4,010
    Good to no this was sorted mate .. :smashin:
    • Thanks Thanks x 1
  17. ICPC
    ICPC New Member
    Jul 15, 2010
    112
    +3
    Yep...well done.
    I knew it would be components :)
  18. snooper
    snooper Member
    Oct 2, 2005
    954
    28
    +68
    I wish i had earlier, lol. Spent a lot of time on sevenforums with mini dumps etc and carrying their recommendations of removing stuff etc and got nowhere for ages. Still in the end its all added to my pc learning curve and there are some clever/helpful guys around, like on here, so can't moan really.
  19. ICPC
    ICPC New Member
    Jul 15, 2010
    112
    +3
    Removing stuff is normally the only way but yeh, when things go wrong is the time we all learn faster with urgency :D
    Now you get to enjoy your machine for the reasons you built it. Oh, and be proud you built it ;)
  20. awebtng
    awebtng Member
    Nov 14, 2007
    12
    3
    No problems with my gigabyte board with kingsdon memory and windows 7. Although one of the bios update stopped the ethernet port working. .later updates were fine
