Freesat remote not working
Discussion in 'Freesat' started by den9112, Mar 14, 2011.
  1. den9112
    den9112 Active Member
    Feb 8, 2004
    2,129
    83
    +258
    Hi i have just set up my humax hd pvr freesat box, all went well untill the remote stoped working ,that is it is working but i am not getting a response from the freesat unit. ...it as worked for the initial set up but now i cannot change channels ,any help as to what the problem could be would be apreciated .Thanks
  2. REPASSAC
    REPASSAC Active Member
    Jan 11, 2011
    2,572
    +393
    Check which button flashes when you press a key and I guess you will find the solution (press the correct one first).
  3. den9112
    Feb 8, 2004
    2,129
    83
    +258
    Got it working....... quite impresed with the humax and the upscaling ,its improved the sd on my panasonic plasma.
