Framed Movie Pictures
Discussion in 'Movie Memorabilia' started by stevos, May 25, 2007.
  1. freshvein
    freshvein New Member
    Dec 28, 2006
    718
    +90
    u can get it from www.moviepostersdirect.co.uk for £16.99 and its double sided, got 2 of them myself :thumbsup:
  2. cooey
    cooey Active Member
    Nov 23, 2005
    5,422
    Media:
    2
    Albums:
    +329
    It's not an original though unfortunately
  3. violinaling
    violinaling Member
    Feb 25, 2008
    288
    +12
    Got the frame and am very happy with it. My rubbish camera really doesnt do it justice. The frame snaps open, and has a thick non-reflective pvc cover which works very well. I'll order 3 more now, which should set the cinema room off nicely :smashin:
    [​IMG]
    [​IMG]
    I also found the best posters to download at http://www.movieposterdb.com/ 5 euros for 100 downloads, not bad :)
  4. chelsea.tone
    chelsea.tone Active Member
    May 7, 2007
    10,000
    +1,138
    Technically its NOT. The Dark Knight writing is also backwards :nono:
    Its framed wrong.
  5. GenVinyardTD
    GenVinyardTD Member
    Jun 20, 2006
    87
    +5
    no actually your wrong.
    as ive already stated.
  6. jdslater1
    jdslater1 Member
    Sep 4, 2005
    886
    28
    +41
    Sorry about the flash!
    [​IMG]
  7. Max Payne
    Max Payne Member
    Apr 25, 2005
    1,264
    +142
    Im not even a Star Trek fan....at all actually - but that framing is class!!!!!!
    • Thanks Thanks x 1
  8. Ickle Yoda1
    Ickle Yoda1 Member
    Jun 25, 2005
    1,030
    48
    +75
    Where can I get an original "Why so serious" poster and how much roughly would I be expected to pay?
  9. jdslater1
    jdslater1 Member
    Sep 4, 2005
    886
    28
    +41
    I'm really only a fan of the films. Really don't like the TV shows (either series) but I'm really looking forword to JJ versions and these poster designs I think are really inspired!
  10. myersfan73
    myersfan73 Active Member
    Jul 11, 2005
    3,470
    +207
    picture lizard Do great custom frames & the more you buy the cheaper they are. :thumbsup:
  11. myersfan73
    Jul 11, 2005
    3,470
    +207
    My original UK John Carpenter's The Thing cinema qaud.
    [​IMG]
    :thumbsup:
  12. nitram100
    nitram100 Active Member
    Apr 7, 2006
    4,863
    +486
    Love the poster, maybe get a betetr frame to compliment such a lovely poster? :)
  13. Max Payne
    Max Payne Member
    Apr 25, 2005
    1,264
    +142
    But the frame suits his speakers? Not evey frame has to be black either. I think it looks very well and suits his setup.
  14. dork knight
    dork knight Member
    Nov 25, 2004
    556
    +10
    Can get the Original on the site mentioned above, costs abit though. £99.99!! :eek: Here
    I really want THIS Dark Knight/Joker poster but want it slightly bigger. Has anyone seen it around apart from the poor fleabay reproductions?
  15. nitram100
    Apr 7, 2006
    4,863
    +486
    Nah, i didn't mean colour at all, i love that sandy colour, i just though it looked abit on the thick side, maybe get a thinner frame. It looks great nontheless
  16. paulgjohnston
    paulgjohnston Member
    Jul 22, 2008
    1,548
    +70
    Lots of posters seem to be 11" by 17" what size of frame would be best suited to these?:lease:
  17. mrbeannn
    mrbeannn Member
    Jul 14, 2007
    546
    +19
    anyone know where to get some really cheap frames sized 36x24 for some movie posters, less then £15 each. thinking either black frames, or even clip ones is nothing better. cheers
  18. SG-22
    SG-22 Member
    May 22, 2007
    1,952
    +217
    Just mounted a few posters,
    [​IMG]
    There are a few more to come but really need some bigger foam board for those.
    Not bad for an hours work and probably saved some money by doing it myself. Cant wait to hang them!
  19. piros
    piros Active Member
    Mar 7, 2004
    3,116
    103
    +414
    Looks great mate, Batman Begins = :cool:
  20. SG-22
    SG-22 Member
    May 22, 2007
    1,952
    +217
    Cheers, Batman is definitely my favourite
    The bigger posters i have to mount next are The Shawshank Redemption, Back to the Future and Dogma
  21. Marcos
    Marcos Member
    Dec 20, 2006
    461
    +13
    mounted on what? i like that look
  22. piros
    piros Active Member
    Mar 7, 2004
    3,116
    103
    +414
    What are you mounting them on/have you got a guide?
    We have 3 joker posters that need to be framed, but this looks pretty good and may be considered as an option as it will be cheap :D
  23. SG-22
    SG-22 Member
    May 22, 2007
    1,952
    +217
    There mounted onto foam board. I got a pack of 10 A1 sheets from ebay at a cost of around £20 (not including delivery). This is the seller I used.
    Mounting the posters is a two man job, you first need to spray some glue onto the foam board then holding each end of poster (one person at either end), one person needs to align the bottom of it with that of the foam board whilst the other keeps the poster taught. Once the bottom half of the poster is stuck in place you'll need to use some form of roller to slowly smooth the rest of the poster onto the foam board, for this i just used the empty tube the poster was sent in.
    Leave the poster to set for half an hour or so then flip it over so that it is now face down, using a craft knife (or Stanley knife) cut away any excess overhang.
    That's all there is to it (hopefully it makes sense). The only problem is that strictly speaking you need A0 (not A1 like i used) size foam board which i couldn't find on ebay and looking around the net getting just 10 sheets will set you back a fair amount (part of the reason for doing it myself was to keep costs down!). Therefore some (around 2 and a half inches) will have to be trimmed from the top and bottom of the poster. Not a major problem with the posters I chose but i was unable to mount a Back to the Future one sheet i had due to heavy text at both top and bottom. Something to bear in mind before going ahead!
    The end result looks great and its a bit different from the norm. Will get some pics up once there mounted on the wall :smashin:
    • Thanks Thanks x 2
  24. cooey
    cooey Active Member
    Nov 23, 2005
    5,422
    Media:
    2
    Albums:
    +329
    Looks good mate!
  25. porter83
    porter83 Member
    Oct 18, 2008
    12
    Here is my framed Manhattan poster. Bloody expensive business getting a poster framed, but my living room has a black and white theme going on and it looks amazing.
  26. Marcos
    Marcos Member
    Dec 20, 2006
    461
    +13
    Is an A1 board fine for Width then? Just comes up short for height by roughly 5 inches?
  27. Soundwave
    Soundwave Active Member
    Mar 9, 2005
    5,679
    +1,072
    I like them SG-22 very well done.
    To be honest the way they are done makes them look like you've got them on Canvas rather than posters.
    I still have my 2 Underworld posters to mount so I may look into doing something similair with them instead of paying the £60+ to get them mounted & framed this time.
    Neil
  28. SG-22
    SG-22 Member
    May 22, 2007
    1,952
    +217
    The posters i used were all 91.5cm x 61cm. Therefore it will over hang the board by only around 1cm and will need to be trimmed but half a cm each side isnt a great deal. The biggest loss will be from the height
    Yea its a lot cheaper doing it your self. works out around £10 per poster (that’s 1 x poster, 1x foam board and spray glue)
  29. cooey
    cooey Active Member
    Nov 23, 2005
    5,422
    Media:
    2
    Albums:
    +329
    Are they original posters or reprints?
  30. SG-22
    SG-22 Member
    May 22, 2007
    1,952
    +217
    Just reprints. The only original i have is for 'Dogma' (UK version) that’s staying in the tube for now (has slight damage on one side any way but nice to have lol)
