Format 1tb hdd to exFAT
Discussion in 'Computer Peripherals & Consumables' started by daftpunk1, Feb 11, 2012.
  1. daftpunk1
    daftpunk1 Member
    Jan 11, 2010
    1,478
    38
    +12
    Ok, I have a 1tb external usb seagate hard drive. It has been formatted to fat32 and been connected to my xbox 360. I connect it to my mac and pc all the time to transfer over media. So never had any problems.
    Except for playing mkv and files over 4gb. I have bought a panasonic bdt-310 blu ray player that will play mkv files and it states if you convert your drive to exFAT you can play files over 4gb on your hard drive.
    Now I have over 600gb used on my hdd so will be a pain backing up and formatting.
    Should I go ahead, will my hard drive still work as good with my xbox 360, mac and pc when formatted to exFAT. No cons about this file partition compared to fat32....?
  2. maf1970
    maf1970 Active Member
    May 2, 2006
    1,772
    +256
  3. daftpunk1
    daftpunk1 Member
    Jan 11, 2010
    1,478
    38
    +12
    Yea its compatible. Good stuff, going to get my drive formatted today....:thumbsup:
