Ford Mondeo CD6000 sound fault
Discussion in 'ICE, Sat Nav & Dash Cam Forum' started by alxgrdnr, Dec 23, 2009.
  1. alxgrdnr
    alxgrdnr Member
    Dec 23, 2009
    Hi All,
    I'm hoping someone out there will be able to help me! I have been to Fords and they are only interested in selling me a new stereo!
    I had the car jump started by the RAC a few weeks back and since the there has been no sound from the speakers - if I turn the volume up as far as it can go - I can just about hear it from the drivers door speaker - The 3 - 6 speaker test is fine and everything on the display is fine - I have the radio code, but the stereo isn't requesting it - is this a common fault???
    I'm hoping maybe it's something to do with the settings - although i have been through everything! I no longer have the manual for it so I have been a bit blind.
    Thanks in advance for any help
    Alexandra
  2. Ben6279
    Ben6279 Member
    Jan 14, 2007
    379
    +27
    In earlier Fords the problem you are describing would be down to an external amp concealed somewhere in the car which has a blown fuse, often caused from the jump start.
    Not sure though if something as new as a 6000 model would still use an external amp though.
    Contact RAC & explain they have caused an electrical fault and you will be taking it to a specialist for diagnostics, see what they say.
    • Thanks Thanks x 1
