Fixing spring clip speaker terminals
Discussion in 'Hi Fi Systems & Separates' started by andrewtayloruk, Jul 13, 2008.
  1. andrewtayloruk
    andrewtayloruk Member
    Sep 29, 2003
    414
    +10
    I've got a Denon DM30 micro system that I'd like to resurrect as a bedroom system. It has those cheap spring clip terminals, one has broken so there's no tension on the clip, as a result the speaker wire won't remain in place (the weight of the wire brings it out).
    Is there a way to fix these clips? I took the back off the Denon and it seems like a single unit, I'm not sufficiently clever with these things to take it any further.
    I assumed this was a pretty common problem and I was hoping you could buy something that piggy backs in the clip to negate the need for the terminal to close.
    Andrew
