Final upgrade time for a while, replace ax100 with........?
Discussion in 'Projectors' started by TopMeTom, Mar 3, 2012.
  1. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Ello,
    Well the time has come to put the final part in place, for now! I have a aging panny ax100 i would like to replace, what suggestions do you have? I am out of touch with pj's so be gentle!
    Viewing distance is about 16ft and the room is 13 ft wide?
    Budget? Not a vast fortune could probably get to 2k?
  2. KelvinS1965
    KelvinS1965 Well-Known Member
    Jan 3, 2006
    11,400
    +2,639
    Are there any JVC X3s still around as that might be just about in budget? Failing that the 2D only Panasonic AT1000 (check model number) is around £2k IIRC.
    I had an AE1000 and my HD350 is miles ahead of the picture quality it gave, so going from an AX100 is a similar (bar the resolution) position, so you should notice a big improvement on either of the above I reckon. That way you'll be good to last a few years without wanting to upgrade again.
    I also will help if your room isn't a plain white/magnolia box, but to be fair if it is, there probably isn't much you can do about it I guess. If you can then you may get a considerable improvement just by improving the room...combine that with a PJ upgrade and the PQ will move on in leaps and bounds.
    • Thanks Thanks x 1
  3. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Thanks mate!
    Just a quickie, One of the in laws is epileptic only at night though, and as such have steered away from 3d i was worried about the reaction? Is that stupid?
  4. KelvinS1965
    Jan 3, 2006
    11,400
    +2,639
    I don't know: 3D gave me a spliting headache at the JVC X3/7 launch in 2010, so I've not bothered since. I wouldn't want to test it out on an eplileptic though.
    • Thanks Thanks x 1
  5. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Just been reading some stuff off the web, think i'll steer clear of 3d!
  6. kbfern
    kbfern Well-Known Member
    Aug 17, 2002
    13,903
    +2,919
    • Thanks Thanks x 1
  7. KelvinS1965
    Jan 3, 2006
    11,400
    +2,639
    Keith, do you have to keep reminding me how cheap HD350s have got these days? :D That's £500 a year in depreciation now mine's 3 years old (must be due it's first MOT :)). Have to agree though for that money with a warranty you could do a lot worse and a HD350 is just as flexible to position as the AX100.
    However, if you do find an X3 in budget even not using the 3D side (maybe sell on the glasses if it helps budget?) it is closer in PQ terms to the HD750 so a worthwhile improvement over the HD350. Also the colours aren't as oversaturated on the X3 either, so less need for an external CMS like I bought. I chose the HD350 when the HD750 was £2k more, but for £500 or so more I think I would have got one, but it's your money/your choice.
    Off to watch a film now...haven't used mine in a while. I'll probably nod off during it though as I was up early: I was like a kid at Christmas as I bought myself a weekend toy today in the form of a 3.0 BMW Z3 roadster rather than upgrade my PJ. :)
    • Thanks Thanks x 1
  8. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    I've found a anthem ltx500(hd750?) for £1200 ish? 12month warranty, worth a punt?
  9. KelvinS1965
    Jan 3, 2006
    11,400
    +2,639
    Double check that it's a HD750 clone and not the older HD100 as that might not be such a good deal (not a bad projector though, just the HD750 had a CMS/THX mode which would get you close out of the box). If you're right that's only £300-400 more than a used HD350 so worth the extra IMHO. In percentage terms it's still about the same as the difference when new.
    Anyway, off to watch 'The Eagle'...hope it's good or I'll be snoring. :D
    • Thanks Thanks x 1
  10. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Yes it has the CMS/THX mode...
    Hope its better than hanna, fell asleep...
  11. kbfern
    Aug 17, 2002
    13,903
    +2,919
    Terribly sorry about that Kelvin:D
    • Thanks Thanks x 1
  12. soupdragon
    soupdragon Active Member
    Jun 22, 2008
    5,135
    +1,037
    Yep!
    My x3 is in the classifieds this morning- £1650 so well under budget.
    Oh, and it's white so even though Kelvin has bought a car, I've a feeling a white x3 would go down quite well with SWMBO ;)
    Tempted topmetom or kelvin? :devil:
  13. plasma_novice
    plasma_novice Member
    May 8, 2004
    510
    28
    +34
    I'm in the same position Tom - virtually certain I'm going to replace my ax100 with an Epson TW9000. The only thing holding me back is that I'm still happy with the image my ax100 gives, especially after I replaced my old manual white screen with a grey tab tensioned electric one. I'm still on my first bulb which has less than 1000 hours watch time, so still performing well, although I'm sure there'd be no comparison putting the ax100 and 9000 side by side
  14. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Thats the thing! I like my image just its been a while since i uograded this part!
    X3, tempting.....
  15. plasma_novice
    May 8, 2004
    510
    28
    +34
    Get yourself down to the doctor quick!!! Sounds like a terrible bout of 'Upgraditis'!!!
  16. KelvinS1965
    Jan 3, 2006
    11,400
    +2,639
    Sounds a good deal, but SWMBO has been very patient waiting for me to get back on with redoing our main bedroom (it was interupted by the search for the car), so further funds are needed for that project. :)
  17. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Id best bump this up as the old warhorse has done for me ax100....im pj-less!
    Typically I had just agreed a deal on the pb12ultra2 sub, so it deffo has to be financed now!
    Help!
  18. plasma_novice
    May 8, 2004
    510
    28
    +34
    I gave in to my inner voices in the end and replaced my ax100 with the Epson 9000. Have to say that even though I was happy with the ax100's picture I'm gobsmacked by the improvement the Epson has given. It really is a night and day comparison. Can't bring myself to sell the ax100 though so its back in its original box and up in the loft with my original screen - sure I'll find a use for them one day!! (or not!!)
    • Thanks Thanks x 1
  19. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    The 9000 is that top of epson range? How would that compare with a jvc/sony?
  20. plasma_novice
    May 8, 2004
    510
    28
    +34
    Yes it is - the comparable models from JVC and Sony are the X30 and HW30
    • Thanks Thanks x 1
  21. Rickyj @ Kalibrate
    Rickyj @ Kalibrate Active Member Assured Advertiser
    Jan 29, 2003
    4,954
    +1,014
    The Epson is a bright projector and thus very good for 3D. The JVC is less bright, but very good at 2d. The Sony falls somewhere in the middle.
    If you fancy a demo of the X30 and the TW9000 you know where we are;) We don't offer credit but there are some very good credit card deals about:)
  22. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Thanks Ricky, me and credit cards..nono!
    Realistically im not into 3d so will be looking for the best 2d i can get...i have concerns over 3d and epilepsy?
  23. corrado kid
    corrado kid Member
    Apr 5, 2004
    1,080
    Media:
    4
    Albums:
    +39
    Kent home cinema offer 12 month payments if that's any good for you?
  24. KelvinS1965
    Jan 3, 2006
    11,400
    +2,639
    Seriously (and I hope I don't come across as a :lesson: here) why not just buy a used model from the classifieds if you haven't the cash to buy a new one? No one needs to get in debt just to buy a projector, the world won't stop if you don't have one and the light nights are here, so you'll be using it less anyway.
    If your circumstances change and you need to sell it a new PJ will lose upto half it's value as soon as you take it home, especially if it's an end of line model.
  25. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Thats probably what im going to do, been watching some bits on ebay, saw a nice themescene hd86 come up yesterday, also following a few mitsubishi's at the moment.
    • Thanks Thanks x 1
  26. Rickyj @ Kalibrate
    Jan 29, 2003
    4,954
    +1,014
    I saw your concerns about epilepsy. That is as good a reason to stay away from 3d:) If you go new most will be 3d capable projectors though.
    There are some good bargains that come up second hand though depending on your budget.
    My only thought is could DLP be a concern for epilepsy. Some people report issues with DLP including headaches. Could that be epilepsy inducing, I don't know.
    • Thanks Thanks x 1
  27. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Thanks Ricky,
    I had a sim2 before that was dlp wasnt a problem at all. 2nd hand it is then!
    Mind you i could try anothe long hdmi cable before forking out? And a grey screen may help
  28. Rickyj @ Kalibrate
    Jan 29, 2003
    4,954
    +1,014
    That is good.
    What is actually up with the AX100 then?
  29. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    No signal on hdmi socket.....
  30. TopMeTom
    TopMeTom New Member
    Sep 8, 2002
    8,242
    +270
    Well it was the hdmi cable.....
    But I am back now looking about, where are we now with all the pj's?
    Ive been offered a hc5000 for £400?
