file transfer info for confused noob
Discussion in 'Freesat Forum' started by ian4355, May 2, 2013.
  1. ian4355
    ian4355 Member
    Nov 14, 2010
    45
    Hi all, confused noob here
    OK, what I need to do is transfer a programme from my foxsat to my pc. As far as I can tell, everything is in place (CF4.1.4, TinyFTP, WebIF), but for the life of me I can't tell where to start. For a start, although it says TinyFTP is installed, I can't find it anywhere!
    I also have Filezilla installed, but I don't know how to point it towards my FoxBox. The problem may be (surprise surprise) is that I don't know how to use FTP programs.
    Please help, someone, and in plain English if possible!
    TIA
    Ian
  2. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,221
    +4,484
    Look in the menus for the Foxbox to find its network address -something like 192.168.1.4.
    In Filezilla that's the host, then you need the username and password.
    • Thanks Thanks x 1
  3. kevkbuk
    kevkbuk Active Member
    Jan 27, 2011
    3,998
    +563
    Install Samba on the HDR then open \\Foxsat-HDR in explorer, much easier and you can map it to a drive letter if wanted.
  4. ian4355
    ian4355 Member
    Nov 14, 2010
    45
    logiciel - thanks, that worked for me
    kevkbuk - this didn't work for me, but I use Firefox, not explorer, so...
  5. ian4355
    ian4355 Member
    Nov 14, 2010
    45
    OK, just tried transfering some files - all of them failed! Isn't this just a case of drag and drop or is it much more complicated than that?
    Edit - using Filezilla
  6. kevkbuk
    Jan 27, 2011
    3,998
    +563
    You'd need to use Windows Explorer nothing to do with web browsers...
  7. ian4355
    ian4355 Member
    Nov 14, 2010
    45
    Oooh by the way, now that CF is in place, can I now get HiDef programmes off my Foxbox on to a USB drive and then edit on my PC (take out ads etc)?
  8. grahamlthompson
    grahamlthompson Well-Known Member
    Aug 3, 2006
    18,759
    163
    +3,102
    He means Windows Explorer not Internet Explorer. You map the drive so it appears as a hard disc on your PC like say C: , just by clicking Start then Explore.
    eg
    How to connect and disconnect a network drive in Windows XP
    • Thanks Thanks x 1
  9. ian4355
    ian4355 Member
    Nov 14, 2010
    45
    kevkbuk - thanks (must have had an extra helping of dumb at lunchtime)
    • Thanks Thanks x 1
  10. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,221
    +4,484
    Click My Computer then type in the address box ftp:// and the 192 etc from before.
    But Filezilla wouldn't let you d-and-d?
  11. ian4355
    ian4355 Member
    Nov 14, 2010
    45
    logiciel - I thought it did let me drag and drop, but all the files failed to copy
  12. logiciel
    logiciel Moderator
    Feb 2, 2008
    46,221
    +4,484
    I guess it depends on which files you were trying for - some will be d-and-d-able, others not.
  13. kevkbuk
    Jan 27, 2011
    3,998
    +563
    Why???
  14. grahamlthompson
    Aug 3, 2006
    18,759
    163
    +3,102
    All the files should be copyable using ftp (by drag and drop), no point in copying them all. The only ones worth copying are the transport stream files (.ts). The other files associated with a recording (.nts .hmt and .tac) will mean nothing to a PC.
    No point in copying HD recordings either unless recorded without encryption.
    • Thanks Thanks x 1
