FAT32 - Still Wont Read USB Hardrive
Discussion in 'PS3 Hardware' started by D2TheQ, Mar 21, 2010.
  1. D2TheQ
    D2TheQ Member
    Feb 10, 2009
    513
    28
    +67
    Why wont the PS3 read my Seagate 320GB USB 2.9 External Hard Drive HDD NR?
    When i check the drive properties it says the file system is FAT32 and it works fine on my laptop and other PC's. When connected to the PS3 it does not even register as a drive, unlike when i use my USB pen drive it registers it and then have to press triangle to view the contents (whats all that about?)
    All help will be much appreciated
  2. RottenFox
    RottenFox Moderator
    Mar 11, 2006
    17,078
    +4,305
    How did you format it?
    if it was on a pc, through windows, theres your answer.
    you have to use something like this: Ridgecrop Consultants Ltd
    and pick " FAT 32 Formatter ", reading how to allocate a drive letter, then go back and select " Windows GUI version of fat32format ", following the instructions.
  3. ljphil78
    ljphil78 Member
    Jan 5, 2008
    190
    28
    +33
    is it a usb powered drive? it maight be that the ps3 cant supply enough power through 1 usb port for the drive to run properly, did the drive come with a Y cable if so have you tried plugging 2 plugs into the ps3?
  4. D2TheQ
    D2TheQ Member
    Feb 10, 2009
    513
    28
    +67
    thanks for the prompt replies ...
    1. Yeah i must of formatted the drive yonks ago using WinXP. I originally thought it wasn't FAT32 so borrowed a mates drive to transfer the data so i could format to FAT32 but when i actually checked the drive properties it said FAT32. Now all the data been transferred to my mates will follow ur link and see how i get on.
    2. The USB has its own power cable. Not too sure what a 'Y' cable is but the PS3 end is the normal USB connection and the hard drive end is the short square connection.
  5. hippo99
    hippo99 Active Member
    Feb 29, 2008
    5,530
    +1,640
    You usually need to connect USB powered HDD's into 2 USB slots on the PS3 using a cable like this, otherwise there isn't enough power supplied to the HDD, & your PS3 won't appear to recognise it.
    [​IMG]
    If your HDD is mains powered then you don't need to.
    • Thanks Thanks x 1
  6. D2TheQ
    D2TheQ Member
    Feb 10, 2009
    513
    28
    +67
    Just formating the drive now using the above software. Just been reading the instructions and surprised that XP cant format anything over 32GB using FAT32. :facepalm:
    Cheers RottenFox for the heads up
  7. Silent-Bob
    Silent-Bob Member
    Oct 31, 2008
    256
    +15
    First I've ever heard of that. I've got several USB powered HDD of varying makes and all work perfectly via one USB connection.
  8. D2TheQ
    D2TheQ Member
    Feb 10, 2009
    513
    28
    +67
    This has worked perfectly however when i go and try and copy a .mkv onto the newly formated drive i get a error message saying "the file is too large for the file system" Any work arounds for this...? :smashin:
  9. jonnyc
    jonnyc Member
    Jan 2, 2009
    1,373
    +203
    you have to split the file so its smaller then 4gb.
  10. D2TheQ
    D2TheQ Member
    Feb 10, 2009
    513
    28
    +67
    Cheers, any suggestions on the software that will do the job?
  11. jonnyc
    jonnyc Member
    Jan 2, 2009
    1,373
    +203
  12. Uridium
    Uridium Active Member
    Jan 29, 2005
    14,361
    +1,881
    You need to read the Ps3 Media guide. Link in my Sig below
  13. Axum
    Axum Active Member
    Aug 27, 2007
    6,137
    +815
    What he said :rolleyes:
  14. D2TheQ
    D2TheQ Member
    Feb 10, 2009
    513
    28
    +67
    Nice one guys... Really appreciate all the help ive found on this forum. If it wasn't for you people i still be watching movies on my 17" laptop using crappy PC speakers and just using the PS3 as a games machine.
    :smashin:
  15. hippo99
    Feb 29, 2008
    5,530
    +1,640
    On my old 60GB PS3 (with 4 USB inputs) I only needed to connect using one USB connection, however on my Slim I need to use 2 USB connections with the same HDD, otherwise the Slim doesn't recognise it.
    Incidentally, most 2.5" caddy's come with the Y cable, just in case of power issues:smashin:
