Factory Reset Sony BDP S550 How?
Discussion in 'Blu-ray & DVD Players' started by Deanooo7, Dec 28, 2008.
  1. Deanooo7
    Deanooo7 Member
    May 15, 2007
    20
    3
    Happy Xmas All.
    I Kindly received a Sony BDP S550 for Xmas from the other half and on Xmas day I set it up round the parents house to demonsrate the quality of Blue Ray:) During the set up I set it to HDMI and 1080P.
    The problem I have is my current TV at home isn't HD ready and I connect via Component, the result is I dont get a picture when all is connected at home.
    Does anyone know how to reset the Player to the Factory set up so I can re-run the set-up sequence again?
    I have checked the manual and it says to re-run the easy setup on the players main menu but seeing as I can't see anything on the screen thats abit of a hard task.
    Regards
    Dean
  2. kingfats
    kingfats Well-Known Member
    Dec 29, 2006
    36,406
    +7,751
    Can you connect via the video connection to get a picture?
  3. Deanooo7
    Deanooo7 Member
    May 15, 2007
    20
    3
    Didn't think of that one cheers :thumbsup:
    Will give a go in minute when the misses has finished watching Eastenders and report back.
  4. Grumpykev
    Grumpykev Member
    Jan 28, 2007
    326
    +47
    You could try this: turn the player on, wait for Home to appear in the display then press left on the remote for a couple of seconds and then down, then hit enter twice. That sequence should have taken you to the factory reset option. Good luck!
  5. 337GUS
    337GUS Member
    Nov 1, 2000
    620
    +18
    To change HDMI to Component
    Try power off/on so DVD shows HOME
    Left x 3
    Up
    Enter
    Up
    Enter
    Down
    Return
    Enter​
    Gus
  6. Deanooo7
    Deanooo7 Member
    May 15, 2007
    20
    3
    :):)All Sorted and off and running, If I read the manual it told me all along!
    I had to hold the Stop button down for 10secs and it resets the player to the lowest Resolution 486i/576i from 1080P and this then enabled me to enter the correct outputs e.t.c.
    Thanks for your help.
    • Thanks Thanks x 1
