Epson TW3200/3600 owners thread - Part 3
Discussion in 'Projectors' started by pacemaker, Nov 22, 2011.
  1. lennon909uk
    lennon909uk Member
    Jan 6, 2012
    2
    Has any had any experience of the Duronic screens available at Amazon. I would like to buy the 133'' but so far been unable to find any reviews of themDuronic EPS133/169 HD Projector Screen 133" - 16:9 Widescreen Matte White Screen - Electric Motorised switch control
    Any advice screen wise would be much appreciated.
  2. yatin c
    yatin c Member
    Oct 27, 2009
    25
    3
    +3
    Hi, Im quite tempted to get the tw3200 or the optoma hd20 as my first projector. Ive read quite a bit of the threads on both of them, and "on paper" I am leaning towards the epson due to the lens shift facility (we are planning to move, but not found the right place yet). Ive been able to have a demo of the optoma at my local sevenoaks, but cant seem to find anyone that stocks the epson projector. Ive tried the epson webchat and phone number and they are yet to get back to me with an answer. I live in Sheffield, but dont mind a bit of driving to get a demo. Any ideas
  3. lennon909uk
    lennon909uk Member
    Jan 6, 2012
    2
    I know Currys Don Valley have one in stock as I recently bought one and wanted to buy in person but the closest one in stock was don valley and I'm in plymouth so got it delivered. Its awesome and I too demoed the hd20 1st but so glad I went for the epson.
  4. yatin c
    yatin c Member
    Oct 27, 2009
    25
    3
    +3
    Thanks lennon, not sure which currys that is, but I'll give the branches around here a call tomorrow. What made you decide to go for the epson?
  5. Keksz
    Keksz Member
    Jun 30, 2011
    23
    at my DUNE mediaplayer (with bluray drive) which video mode should I use for 1080 MKV movies and Bluray discs?
    1080p 23.976Hz
    or
    1080p 24Hz
    Thanks!
  6. kbfern
    kbfern Well-Known Member
    Aug 17, 2002
    13,984
    +2,970
    same difference one is just the rounded up figure for the other.
  7. wolvers
    wolvers Active Member
    Jun 10, 2008
    6,453
    +1,114
    They're not the same at all. Most movies are produced in 23.976fps (or 2400/1001 as it's sometimes referred to) but some, often Asian, films are produced in exactly 24fps. Some players, if not set correctly for the correct movie will produce stuttering that is most likely to be noticeable on panning shots. Some UK based movies are produced in 25fps and that will be worse.
    For some displays, a PC's GPU control panel will give you the option of either. In my case the AMD panel only gives the option of 24hz, but the 3200 reports that as being 23.90hz and plays back 23.976fps material perfectly. 24fps however does not so you have to be aware of what the source material is and how the player and display are interacting.
    I'd go with 23.976 and test out some material to check that is plays smoothly. Something like the opening panning shot in the dark knight is a good test.
  8. Keksz
    Keksz Member
    Jun 30, 2011
    23
    ok, thats good then, I am using the pj since july with 23,976 :-D
    never noticed any problems, but I was curious
  9. Ewan154
    Ewan154 Member
    Aug 2, 2005
    1,915
    +68
    I keep getting "source: hdmi 1 no signal. I have tried plugging the projector into the ps 3 and sky HD box, but get no signal.
    Should I contact Tesco or Epson?
    How do I contact Epson?
  10. wolvers
    Jun 10, 2008
    6,453
    +1,114
    What about in HDMI2?
    How long have you had it?
  11. Ewan154
    Ewan154 Member
    Aug 2, 2005
    1,915
    +68
    Had the hdmi cable for a few years. Tried hdmi 2 and still get the same.
  12. wolvers
    Jun 10, 2008
    6,453
    +1,114
    I meant how long have you had the Epson?
    Might be worth trying another HDMI lead if you have one.
  13. Ewan154
    Ewan154 Member
    Aug 2, 2005
    1,915
    +68
    Had the PJ for about 4 months now. Tried another hdmi cable and it works fine,so it looks like it's the hdmi cable.
  14. wolvers
    Jun 10, 2008
    6,453
    +1,114
    Result! :thumbsup:
  15. muzzi
    muzzi Member
    Mar 3, 2005
    1,702
    48
    +93
    Hi all,
    I'm looking into getting a 3200 PJ from PiPro.de ( I live in Germnay) and they can do a calibration for an extra 100Euro. However the calebration will be done in store. I presume this should stil give a better image than not having it callibrated, or will it/could it screw up the picture completely?
    They also have the option of the calibration and the lens filter for 150 Euro. Is the lens worth it as i don't have a batcave :-(
    linky
    Kompetenz in Beamern - Epson EH-TW3200 Epson EH-TW3200 001636
    Muzzi
  16. kbfern
    Aug 17, 2002
    13,984
    +2,970
    Unless they calibrate in your room the money is wasted unless your room and theirs has the same conditions.
  17. muzzi
    muzzi Member
    Mar 3, 2005
    1,702
    48
    +93
    This was my thinking,
    However if you flip it around, there would never be a room environment that would be perfect for out of the box settings, so although the calibration may not be perfect for my room, it would be better than out of the box settings?
    (or am I talking rubbish as normal )
  18. kbfern
    Aug 17, 2002
    13,984
    +2,970
  19. wolvers
    Jun 10, 2008
    6,453
    +1,114
    Your service is a bargain!
  20. muzzi
    muzzi Member
    Mar 3, 2005
    1,702
    48
    +93
    Cool thanks.
    Muzzi
  21. barakoas
    barakoas Member
    May 29, 2007
    hey folks
    i got one question.. If you could choose new projector today.. and have two options to choose from.. would you go for TW3200 again or it would be TW5900/TW6000
    I know the features of both.. i just really would like to know your opinion.. :blush:
  22. Beard of Steel
    Beard of Steel Active Member
    Oct 30, 2006
    1,013
    +293
    I suppose it really comes down to whether you want 3D or not and also if you require a very flexible lens shift.
    I use quite a bit of lens shift and at this point in time im not that fussed about 3D, although that may change if I seen a demo and it blew me away, then I may consider upgrading.
    For the money the TW3200 is an excellent PJ and produces a quality picture so I would stick with that for the time being.
  23. pmymmw
    pmymmw Member
    Nov 6, 2008
    3
    Hi all,
    I am thinking of buying a TW3200 but just wanted to check it would work OK in my conditions before I did.
    My lounge is almost 22' long so I will probably end up with a throw distance of around 19-20'. I was thinking of buying a 106" screen. I know from the calculator on projectorcentral I will have to have the zoom quite close to one extreme on the projector to achieve this, will this have an adverse effect on the picture quality?
    Thanks for the help.
  24. Beard of Steel
    Oct 30, 2006
    1,013
    +293
    Ideally you would want the throw to be around the 15'-18' mark max. If that isnt possible you may want to look at a screen with a slightly higher gain, possibly around 1.5, especially if you are using it in a room with light walls and ceiling.
    • Thanks Thanks x 1
  25. wolvers
    Jun 10, 2008
    6,453
    +1,114
    Surely when you zoom in, it will be at it's brightest? AFAIK, you loose brightness as you zoom out to a larger image.
    • Thanks Thanks x 1
  26. Vol666
    Vol666 Member
    Jun 29, 2011
    29
    9
  27. woppy101
    woppy101 Member
    Sep 12, 2008
    787
    28
    +65
    They look like dust blobs to me
  28. Vol666
    Vol666 Member
    Jun 29, 2011
    29
    9
    I change the hdmi cable and now its fine....
  29. pigginbacon
    pigginbacon Member
    Sep 30, 2010
    1,330
    48
    +68
    I posted on Part 1 of this thread about the slight dimming / flicker problem I was having with the 3200.
    I notice a few other people have had this.
    First of all I got out the Epson engineer and they replaced the bulb. This worked for about a month before the problem re occurred. I got the engineer back out again and was given a replacement unit.
    Now I have just noticed this unit has started doing it too. There is only 27 hours on the bulb.
    I'm not happy at all.
    Has anyone managed to get this sorted?
  30. kbfern
    Aug 17, 2002
    13,984
    +2,970
    Flicker is something that can effect all projectors and it is fairly common.What is not common is that it happens so early in a bulbs life.
    The normal way to cure this problem is to run on full/high brightness for 10-20hrs then put bulb back down to eco mode.That will normally stop the issue for another few hundred hours but I am not sure why you are having this problem so early in the projectors life.
