Epson TW3200/3600 owners thread - Part 3
Discussion in 'Projectors' started by pacemaker, Nov 22, 2011.
  1. pacemaker
    pacemaker Member
    Aug 31, 2003
    532
    +17
    (MOD COMMENT : Hi. Please use this thread as a continuation of part two which can be found here....Part 2)
    re my flickering fault:
    4 hours in 'normal' mode seems to have cured it. time will tell if it lasts, if not its on to epson for a new bulb/unit
    Wolvers how did you get on?
  2. wolvers
    wolvers Active Member
    Jun 10, 2008
    6,453
    +1,114
    The engineer turned up with a replacement unit, but after discussing the issue with him he just changed the bulb which he was able to do in situ. I have to say I was happier with that outcome, If the fault is still there at least I know it was definitely the unit. So far it's been fine, although it's only been on for a total of about 4 hours.
  3. kbfern
    kbfern Well-Known Member
    Aug 17, 2002
    13,896
    +2,909
    I wonder if changing the bulb means your one off replacement during the 3 yr g/tee period has now been used or not.
  4. tonytof
    tonytof Guest
    1st time poster, please be gentle ;)
    I've recently got my TW3200 and currently have my Sony BDPS350 BD player attached. When playing back blu-rays the image is stunning and am well pleased with everything
    But when I put a standard DVD movie in the BD player (and also when just on the BD players menu system) every 20 or so seconds it glitches as it appears to start trying to display a blank grey screen (most noticable in the bottom half of the screen) momentarily.
    As a test I've tried my HTPC (XBMC) playing standard dvds and this effect doesn't happen, so appears to be a problem with the BD player? Have also tried changing the signal settings on the BD and projector and that hasn't helped either.
    Was wondering is anyone else had come across this problem please?
    Can anyone recommend a BD player that they know plays back BD and DVD fine with a TW3200 (i'm in the UK) please?
    Tony
  5. SimonG156
    SimonG156 Member
    May 18, 2004
    118
    +3
    I have the 350 and have had no such problems. Is it connected direct or through an amp?
  6. SimonG156
    SimonG156 Member
    May 18, 2004
    118
    +3
    You could fix the output from the 350 to 1080p and see if you still get the issue.
  7. wolvers
    Jun 10, 2008
    6,453
    +1,114
    Will they only do a replacement once? I thought someone here had theirs replaced a few times.
  8. kbfern
    Aug 17, 2002
    13,896
    +2,909
    Well you are allowed 1 FOC bulb replacement during the 3 yr warranty,they can change the pj as often as needed though as the engineers seem to swap out faulty pj's rather than take them back for repair.
    So as your bulb was replaced for being faulty I was just wondering if that counted as THE foc replacement or not.I guess we won't know till if and when your bulb actually dies.
  9. tonytof
    tonytof Guest
    It's connected direct, hdmi.
    Have tried the 350 set to Auto and 1080p and same thing happens. When at the BD menus it sometimes stabilises until I play a DVD but other times it glitche's every few seconds. Tried some more settings combinations but to no avail.
    So last night I tried my RDR-HXD995 (freeview + dvd) attached via HDMI, using the same settings as the 350, and that works fine, so definitely looks like a fault with the 350? Though as yours is ok, looks like my 350 is faulty.
    I'll have to bite the bullet and get a new unit, not sure which to get though
    Tony
  10. tonytof
    tonytof Guest
    The weird thing is that until I put that 1st DVD in the 350 (it had never had one put in before as far as I can remember) the menu screens didn't have this flicker
    Am going to try the 350 on a TV later
  11. kbfern
    Aug 17, 2002
    13,896
    +2,909
    Have you tried various dvd's or just one,is it a home made dvd or a pukka original and is it a region 2 disc.
  12. tonytof
    tonytof Guest
    Tried a few different DVD's, the one I'm using for testing at the moment is a region 2 ghostbusters orginal pukka disc
  13. tonytof
    tonytof Guest
    Just plugged the 350 into a TV and menus and dvd playback seem rock solid
    Really not sure what the problem might be given other devices don't have th e same problem plugged into the epson
    Will try a different hdmi cable just in case
  14. wolvers
    Jun 10, 2008
    6,453
    +1,114
    They said to me that they are good for 4500-5000 hours in Eco mode so I would assume it's a warranty change as opposed to a FOC bulb change for it dying after loads of hours. Mine had done 1400. I would argue that anyway! :p
  15. Beard of Steel
    Beard of Steel Member
    Oct 30, 2006
    993
    +278
    If you remember I had the same problem as you with the flickering. I had it not long into the bulbs life, maybe 100-200 hours and ran it in normal for about 10 hours I think and that solved the problem.
    This problem returned after about 1500 hours so I ran it in normal mode for about 20 hours and it went away again.
    Its now been in eco mode for about 40 hours with no problems so far *touches everthing wooden*, if not I may need to go down your route.
  16. tonytof
    tonytof Guest
    Well I connected the BD player to HDMI2 last night, and it was working fine, very odd.
    Will have to see how it goes, and perhaps pick up a new hdmi cable and try it back on hdmi1
    Tony
  17. tonytof
    tonytof Guest
    Am now wondering, as i have a grey screen, if what i'm really seeing is the bulb flicker mentioned in other posts!
    Does the display go off completely or do you lose, say, about 1/2 the image as the flicker is so fast please?
    Tony
  18. wolvers
    Jun 10, 2008
    6,453
    +1,114
    No, the output level of the bulb dips slightly but it doesn't cut out completely. Sounds like you're having HDMI handshake issues.
  19. tonytof
    tonytof Guest
    Ok, many thanks
  20. technomong
    technomong Member
    Sep 14, 2006
    58
    Well, the TGW3200 arrived today. Prompt service from Epson.
    It's bloody gorgeous. This is my third PJ: a Panny ax100, the Epson TW1000, and now this. Even though we've been without one for a while, it's clear from the start that the quality is another step up. Lovely punchy picture, in cinema mode. Haven't played with the settings yet, straight out of the box it looks very nice.
    Happy man.
  21. SimonG156
    SimonG156 Member
    May 18, 2004
    118
    +3
    I was looking at the talk about nd2 filters in the previous thread as a solution to black levels. One silly question. How does a neutral density filter differ from turning down the brightness?
  22. Ewan154
    Ewan154 Member
    Aug 2, 2005
    1,917
    +68
  23. Showman
    Showman Member
    Nov 20, 2011
    12
    Hi everyone, I am about to commit to buying a TW3200, and have specifically chosen this machine - apart from the good reviews here - because it can cope with the 5M + throw to an 80 inch screen. (according to the calculators I've seen) This is just within it's limits, but will put it physically very close - about 1 inch away - from a wall through wich it will be projecting. will this be enough room for the front air exhaust to work properly?, as I can't make another hole to solve this more directly.
    The other question is simply; before I finally commit to buy, Who is offering the best price for a 3200 at the mo.?
    Thanks in advance!:)
  24. SimonG156
    SimonG156 Member
    May 18, 2004
    118
    +3
    The service I got from Projector Point was excellent. The pricing is very competitive.
  25. Ewan154
    Ewan154 Member
    Aug 2, 2005
    1,917
    +68
    Sometimes when watching sd telly programs I get a fuzzy.broken up line on the top bar and the bottom bar. Any suggestions?
  26. Showman
    Showman Member
    Nov 20, 2011
    12
    Hi Simon, thanks for the reply.
    Yes I've been impressed with Projectorpoint's service and pricing from what I've read here too. The only other place I've seriously considered is Epson UK, and I see they have warranties of 3 and 2 years for the lamp and pj respectively. I may have imagined it, but did I see somewhere that they (Epson) were offering 3yrs on both? or was that just some limited time offer?
  27. wolvers
    Jun 10, 2008
    6,453
    +1,114
    Yeah, I get that. I think it's only on upscaled SD programmes from the SkyHD box. Never does it on proper HD content.
  28. Showman
    Showman Member
    Nov 20, 2011
    12
    Think I've solved the mystery of the 2 or 3 yr warranty on the 3200 pj. I see 3 years (lamp AND pj) is offered on Projectorpoint's site, so with Their offer of an HDMI cable thrown - in, My decision is now more filmly with Them. I'll order it tomorrow, and when I get it, will of course, be posting My views and installation details here - I only hope I've got My throw calculations right!!
  29. lantis
    lantis Member
    Nov 28, 2011
    2
    hi guys.
    is there anyone who is using the epson tw3200 with a med8ter media player?
    i'd like to know if you calibrated them.
    if you don't have the mede8ter, do you know where i can find some calibrations (already done, not pattern test) of the epson??
    i dont have a colour meter :rolleyes:
  30. Campsie
    Campsie Member
    May 16, 2011
    My tuppence worth for those considering, don't hesitate!
    Admittedly I am new to all this home cinema malarkey so others may look at with a keener eye and ear, but I took the plunge and set up with Onkyo 609 amp, Q Acoustic 2000 speakers, Sony BDPS580 BD player. Best £2K I have spent - loving it:D
    Even the mother in law, with all those withering looks and comments whilst wiring up, has admitted that all is forgiven having watched that bl00dy dancing show of a Saturday evening on it!
    Kids have sat slack jawed and a variety of adults have got lost in the opening scenes of Cars on BD. DVDs are surprisingly sharp although SD tv is rubbish (Virgin), needs to be HD if watching something worth watching on it. But the HD / BD stuff is incredible.
    I have mine just projecting on to the wall (painted white) as funds depleted - positioned just over 5m from wall it fills the full opposite wall of 3.35 metres without a problem. I guess I would need to see it with a screen to appreciate the difference, but I just can't imagine how much better it could get?!
    Anyway, everyone who has come to see it has pretty much gone away to measure up their houses to see if they can fit one in.
    Go buy!
