Epson Perfection 1650 Scanner Driver For Win 7 64bit
Discussion in 'Computer Software & Operating Systems' started by Garrett, Jun 16, 2012.
  1. Garrett
    Garrett Moderator
    Apr 21, 2001
    23,202
    +1,634
    I thought I share this very helpful video that helped me install the scanner driver that I could not find from Epson.
    Hope this helps someone who's upgrading to Win 7 64 bit.
    • Thanks Thanks x 1
  2. Alan CD
    Alan CD Well-Known Member
    Jul 15, 2008
    10,893
    +2,439
    Thanks for that.
    I have an old Epson Perfection 1200 Photo which has done sterling service over the last 12 years.
    But I am now researching for a new PC and obviously it will be with 64-bit Windows 7, so this video shows anything is possible!
    :thumbsup:
  3. rayhutt
    rayhutt Member
    Jul 29, 2013
    Garrett. I wonder if you have any new information regarding the Windows 7 64bit driver for the Epson Perfection 1650, as the link in your YouTube clip is no longer active. Cheers.
  4. sparky10
    sparky10 Member
    Mar 16, 2008
    1,039
    +154
    Hi, try this Epson link, should do it for you.:)
    Epson Perfection 1650, Drivers & Downloads - Technical Support - Epson America, Inc.
    Hi, following the link through it appears to lead to a third party download which may or may not work.. However, using the web site 'Driver Guide' I have sourced several drivers that should (hopefully!) do the job.
    http://members.driverguide.com/driv...=1375128867&ref=h2&gqm0=epsom perfection 1650
  5. Garrett
    Garrett Moderator
    Apr 21, 2001
    23,202
    +1,634
    After your message I just did a web search and got the video I posted at the top, I came back to edit it and find the link above still working.
    Anyway I downloaded the video above for reference in case I ever need it again and it does disappear.
