akarit1
Established Member
- Joined
- Feb 24, 2004
- Messages
- 492
- Reaction score
- 15
- Points
- 157
looks like you would have the lens shift near max there..... I've a smaller room and smaller screen than you and mine ended up just perfect on max shift
although I didn't need to use it and its like using a bad word with projectors as its best not to use if you can get away with it but the keystone setting in the menu will get rid of the trapeoid shape you mention..... which is due to having the projector pointing down slightly
It's only a slight trapezoid so I have not used the keystone. I may just have to live with it or raise the picture a bit to minimize the trapezoid...just thought it would be ok with an almost 100% vertical LS.
