Energy saving GU10's
Discussion in 'Renewable Energy & Energy Saving Forum' started by criticalmass, Apr 9, 2009.
  1. criticalmass
    criticalmass Member
    Feb 28, 2005
    516
    28
    +43
    My new house used to have 4 x 50W GU10 downlighters in the kitchen, about 2 years ago i replaced them with low energy GU10's. Not thinking at the time that they're probably not all made equal i just bought a set of 5 off ebay for £24. They're a little bit dimmer than the normal halogen bulbs which i can live with to an extent however they take an absolute age to light up, i'm talking around 2 or 3 mins to become fully lit (they start off pink) & i'm now finding when i walk into the kitchen i either put the dining room light on or put the cooker hood lights on (2 x 40w) which is completely defeating the object.
    Can anyone recommend replacement bulbs that dont cost an absolute fortune, give out a similar light to the halogens & have a decent beam range? Realise i might be asking too much here. I've seen the Zenigata LED bulbs which get rave reviews and seem to tick all the boxes but they cost around £25 each which would take a few decades to recoup in saved electrcitity costs.
  2. robh2002
    robh2002 Member
    Mar 7, 2002
    300
    +23
    If you use these bulbs for around 3 hours a day throughout the year, it'll take around 2 years to recoup the cost...assuming £0.21 / kWh and 50 pence purchase price for the halogen and £23 for the LED.
    Can't think of any other option to help you - sorry. I think these LEDs are likely to be the best idea.
  3. Member 310233
    Member 310233 Member
    Sep 25, 2008
    22
    3
    The LEDS are going to last a lot longer too. If you reckon a white LED has a lifespan of 50,000 hours, they are going to last 45 years at 3 hours a day, so you aint going to changing them too often.
  4. Nic Rhodes
    Nic Rhodes Active Member
    Mar 23, 2001
    17,134
    +1,314
    Has anyone tried the Zenigata LED yet? I have tried several LED and mega GU10s and found them all too dim compared with 50w Halogen GU10s.
  5. sean5302
    sean5302 New Member
    Sep 21, 2005
    1,391
    +84
    What purpose do you seek in changing the standard GU10s?
    If you want lights to see by, the LEDs are useless IMHO.
    If you want to save money, £25 a pop for Zenigatas is also useless.
    If it's not broken why fix it?
  6. Phil57
    Phil57 Active Member
    Jan 31, 2005
    3,690
    +517
    .............err, the OP answered that question ten days before you asked it!! ;)
  7. t72bogie
    t72bogie Active Member
    Jul 17, 2007
    3,101
    +539
    I had the same dilemma - we moved into a new house 18 months ago, and then realised that the nice spotlights everywhere were costing us a fortune ...with most of the lighting from 52 x 50w GU10 spots !
    so go LED everyone says and then you see the prices - which are a joke when you consider you can get a regular energy saving bulb from Tesco for 99p these days, I dont fancy paying £25 a bulb to replace all the GU10s :thumbsdow
    anyway, I spend some time on ebay and must have tried about 6 different types over a 2 month period before I was ready to give up, before I finally found some that gave the right price/performance ratio - ten quid a bulb and light that was manageable...sure it wasnt as bright as the 3 x 50W they replaced in the same fitting, but more than adequate ...to be honest, most of the lighting is really mood lighting anyway
    So I did the kitchen first which has a bank of 4 and 2 banks of 3 x GU10 - so 10 bulbs and £100 total to replace them - been fine since
    these are what im using - as always, best just buy one first and try it out to make sure its good enough for your requirements
    4 Eco-friendly Warm White 3x1W LED GU10 Bulbs on eBay, also LED Lighting, Lights, Lighting, Home Garden (end time 15-May-09 19:42:37 BST)
  8. psikey
    psikey Active Member
    Oct 5, 2005
    6,517
    +702
    I'm an Energy Consultant usually advising companies on how to reduce their energy & been looking at GU10 LED's for ages to replace my own 30W or 50W Spots.
    Most have pitiful light output or have overheating issues leading to premature failure.
    I recently found some 4W Hyperbright ones which come with a 12 month warranty (rare for LED lighting) and even though they are around £22 each they really are close to a 50W for light output, I'd say around 40W.
    They have a large metal heat sink facia which will hopefully eliminate the overheating issues of early generation GU10 LED's
    I bought 4 for for the kitchen with free delivery & worked out at around 3 year payback based on projected lighting use.
    Info here: EXERGI LED GU10 and LED MR16 Energy Saving Light light bulbs
    Always choose the Warm versions as others are too blue in cooler. The Warm give out less lumens/watt but close to flourescent in light colour (none are as warm as Halogen).
    The litmus test is that the wife is actually happy with these too !!!!
  9. criticalmass
    criticalmass Member
    Feb 28, 2005
    516
    28
    +43
    How do these stack up against the Zenigata bulbs which "seem" to be generally regarded as the best & the closest you can get to a halogen in a led package. Beam angle is 120 degrees, whats it like with the Exergi?
    Edit : Just checked and the beam angle for the Exergi is 38 degrees compared to the Zenigatas 120 degrees. Bit of a difference there
  10. psikey
    Oct 5, 2005
    6,517
    +702
    Must admit I've not been too concerned about beam angle. As my spot ligts are generally "spot lights", not general wide lighting.
  11. Swabypool1964
    Swabypool1964 Guest
    Just bought a shed load (44) of energy saving fitments (Hispec) that include a 'daylight' GU10 11w 6400k lamp.
    Now in hindsight maybe I should have gone to check ONE out before embarking on my mission to save the planet and become an eco warrior!
    The light in the living room where there are 12 of these beauties is moon like, with this blue haze. What can I do? How can I replace them?
    I have ordered 6 14w Megamans Low Energy Spotlight GU10 14W 830 15K Hr Megaman 14 Watt on a trial basis (new out so am waiting a while for them), I am hoping these give off the brightness and warmth needed in the living room. The fitments are too long for a normal halogen and anyway they only have a maximum wattage of 11W (hoping an extra 3 watts won't matter).
    If these don't cut it can anyone out there advise me on where I go from here?
  12. Lee_JTD
    Lee_JTD Member
    Dec 23, 2007
    121
    +14
    standard halogen GU10 bulbs are generally 38-42 degrees, so they are closer to the original spec you are looking at replacing.
  13. gurkey
    gurkey Member
    Sep 13, 2007
    22
    3
    Any results yet to report for the new 14W Megaman GU10 MM14152 ?
  14. DOW24
    DOW24 Member
    Oct 2, 2004
    10
    Just my two pennies - I'm really hoping that this is the answer to lighting...
    Have a fair number of cool white and warm white GU10 LED bulbs around the house now, the oldest have been in place for a coulpe of years with no failures. Reliability is excellent compared with the compact fluorescent GU10s - I found the CFLs didn't last long, especially when switched on and off throughout the evening, but that's probably not much of a surprise. The worst lasted about a month, others followed quickly after. Perhaps reliability is better now but I've replaced them all with LED lamps.
    The most recent LED lamps I've bought are 3w single LEDs for around a tenner each and they put out a reasonable amount of light but still nowhere near a 30W halogen. Cool white is brighter than warm white (and looks great lighting a black slate floor!) however the beam angle is pretty narrow so casts a pool of light on the floor. Mine stay on most of the evening but are supplemented with cool white fluorescent uplighters when we are using the room.
    They come from Kymanledtex.com - suppliers of eco lights and products though have to be bought via e-bay but I've had no trouble in the past...
    I have recently installed an LED strip light from the same company which belts out a fair amount of light for 8 watts but its not particularly attractive - I just wanted to see what it was like!
    One tip: some LED replacement bulbs do not fit into some fittings - I've had to file the downlight holders before to get the body of a bulb to fit and also if the bulbs are held in by a spring clip, the lip of LED bulbs can be a bit thicker than standard so that needs some work too.
    The technology is advancing but isn't quite there yet; surely it cant be long, the energy saving potential is huge...
    Thanks all
  15. Andy1980
    Andy1980 Guest
    We have also had a problem finding LED 50w equivalent gu10 bulbs.
    We finally settled for CFL versions and even found a 30w equiv bulb that was the same size as a standard halogen bulb.
    If any one has any led high light output GU10 bulbs that are as good and as small as a halogen 50w please post back.
  16. robh2002
    robh2002 Member
    Mar 7, 2002
    300
    +23
    Just bought and installed one of these to test
    Zenigata - all purpose power LED
    It's pretty good, but perhaps I should have done for the medium beam version as it does not seem as bright as a 50W halogen - but certainly closer than any other.
  17. simonbagger
    simonbagger Guest
    The savings of LED have moved me to install Zenigata 4W LED GU10 Bulbs. They might be top end on price but I know the savings will come.
  18. dekoded
    dekoded Member
    Oct 30, 2004
    893
    +59
    Wow, these LED GU10's are a bit pricey!
    I fancy changing the Halogens in my kitchen but don't really want to spend several hundred quid!
    I found these: GU10 78 LED Home Studio Spot Light Lamp Bulb Spotlight
    and whilst I'm sure they're not as good as the ones mentioned in this thread they are much cheaper, but are they worth buying?
  19. robh2002
    robh2002 Member
    Mar 7, 2002
    300
    +23
    In my opinion, I wouldn't touch these types of LED bulbs. Based on similar designs sold at B&Q, they have very poor light quality, poor spread and don't last very long. They give LED bulbs a bad name.
    If you think the other LED are more expensive, calculate how much you are paying to run them and they will look rather cheap overall compared to 'cheap' halogen bulbs!
  20. nheather
    nheather Well-Known Member
    Oct 6, 2004
    12,297
    +2,259
    Interested in the Zenigata GU10s.
    Anyone here used them?
    If so how would you compare
    (i) Brightness compared with 50W Halogen
    (ii) Spread of beam compared with 50W Halogen
    Which colour did you go for, White or Warm?
    @robhowell
    Just read your comment - what do you mean by medium beam version - I can only see two versions White or Warm.
    Another Question
    Ignorring the wattage as you can't directly compare that, I notice that the Zenigata is 200 Lumens but the Halogens are 500 Lumens.
    How on earth can they be comparable given that one gives out 2.5x the light of the other?
    Cheers,
    Nigel
  21. robh2002
    robh2002 Member
    Mar 7, 2002
    300
    +23
    You know, I now have no idea what I meant by the medium beam version! I presume I meant a warm white version.
    Its obviously very difficult to talk about brightness as it's one opinion verses another as I don't have a light meter. However, I'd say the LED was something around 50-70% of the 50W halogen it replaced - with a similar beam spread. There is certainly no spot light effect with the LED. I went for warm white as this seems very similar to the halogen it replaced.
    My bathroom was WAY over lit with 5 x 50W halogens, so turning it down a bit was a good thing.
    Cheers,
    Rob.
  22. John
    John Moderator
    Dec 13, 2002
    9,752
    +1,636
    A 35W halogen would have been 70% of the 50w one ;)
  23. leon
    leon Member
    May 15, 2001
    1,125
    +64
    i maybe able to help aliitle i have been using led for the last 4 years in my house in the forms of gu10 fitting
    type one cluster led these were great about 4 years ago only 1w to power and about 15w of light downside the leds will sometimes fail in the cluster they generate zero heat and are great for mood lighting (white light only) which is whiter than the standard gu10 filement bulbs (£5.00each)
    type 2 are single leds that one bright led in a single mirror tube these are bright then the type 1 and i have never had one fail in 3 year they come in white light ( blueish) and warm white simular to the filament bulbs ..they use 1w around £8.00 each
    type 3 are 3 x 1w in and array same as type 2 but three of them brighter than the type 2 beware of the imatation ones on flee bay they give of a very yellow light and do not last as long as the proper ones ,,u get what u pay for cost around £15.00 fake ones are £10.00 each ..3w and give out around 25w of light
    type 4 the ultimate ones are cree chipset look the same as the type 3 with three led these ones have a long glass luxeon bulb inside a good way to tell the proper ones from fake underpower ones these cost around £18.00 each they give out the same light as the original filement light bulbs all be it in a smaller beam .. 3watts to run and give allittle heat ok to pick up in your hand after 3 hours of use ..
    payback on these bulb with normal use around one to two years they are good for around 60 thousands hous which is amazing..
    it very tricky to get hold of luxeon bulbs in the uk as the shops dont like to sell the everlasting light bulb :)
    ive been importing cree/luxeon for years now from the usa and there performance is amazing ..im not a business just sell them to friends
    hope this helps
  24. nheather
    Oct 6, 2004
    12,297
    +2,259
    So how do these compare with a GU10 50W Halogen.
    I've been looking at the Zenigata which are claimed to be a direct equivalent replacement but I'm confused by this when I look at the claimed Lumens output for each
    Zenigata - 200
    50W Halogen - 500
    I just struggle to see how these can be comparable.
    My concern, is that whilst I would love to replace the 11 in my kitchen, the light level isn't great with Halogen so I don't want to pay £250 for something that is worse.
    I did put the question of YourWelcome and they seemed a little taken aback by the 200 lumens versus 500 lumens but they did they concede that the Zenigata aren't as bright as a 50W Halogen. They did say they offer a keep of return service so I might buy one to try them out.
    They also said that it maybe better to wait until next year - there is another step up in technology coming through and they expect to have true 50W GU10 (and better) replacements then. Although they said that they have had the first examples for testing and haven't been very impressed so far.
    Cheers,
    Nigel
  25. leon
    leon Member
    May 15, 2001
    1,125
    +64
    nheather
    the cree luxeon are the same as a 40w gu10 imoa and the white light version is slightly brighter than a 40w gu10. its the first time ive been able to use led bulb that give out the same power in light :)
  26. Tolly
    Tolly Member
    Feb 13, 2004
    44
    11
    Read this about the Master LED lamp 7W.
    Recalled ProductsBETA
    uk and european product recalls by email and rss
    Master LED lamp 7W 230 Dimmable
    19-Sep-2009
    Details
    Brand: Philips
    Type/number of model: GU 10 E27 standard, E27 NR63
    Description: Lamps intended for professional use, but some may have been fitted for domestic use.
    Country of origin: China
    Danger
    Electric shock
    The product poses a risk of electric shock because the overheating of one component of the power supply of the lamp may damage the electrical fitting and/or the luminaire.
    Action Taken
    Voluntary stop of sales and withdrawal from the market by the manufacturer.
    The Next Step...
    If you purchased this item, get in touch with the place you bought it from to find out what to do next.
    If you live in the UK and need further advice, please contact Consumer Direct on 08454 04 05 06 or Consumer Direct.
  27. Member 414737
    Member 414737 Member
    Oct 23, 2009
    12
    3
    That was actually an old lamp. That is the 7W 35W equivalent GU10 dimmable lamp. The first version that Philips brought out. All of these were recalled at the beginning of the year, not September as your post claims. Since that model there has been version 2 35W Dimmable 7W, MR16 20W Equivalent Dimmable and now the 50W equivalent 7W dimmable lamp.
  28. leon
    leon Member
    May 15, 2001
    1,125
    +64
    ouch im glad i never bought them ones :eek:
  29. Member 414737
    Oct 23, 2009
    12
    3
    I have 5 of those lamps in my kitchen! I figure that even if they do overheat they will still never get as hot as a halogen lamp does at full light output, so I didn't really understand why Philips recalled them! The company are spending a lot of time and money positioning themselves as the market leader in LED retrofit lamps and light fittings so I think this was more of a precautionary measure. I will let you know if they overheat or not in about 42,800 hours!
  30. nheather
    Oct 6, 2004
    12,297
    +2,259
    I must admit that I remain unconvinced because I can find no-one (forums, manufacturers, retailers) who can answer my simple question.
    Ignorring watts, because halogen watts and LED watts are just not comparable in light terms and looking at the technical measure of light output so we are comparing apples with apples
    Zenigata - 200 Lumens
    Philips Master LED (50W replacement) - 250 Lumens
    50W Halogen - 500+ Lumens
    So how can these LED equivalents be as bright when they are giving out <50% light?
    Cheers,
    Nigel
