emulators and games in drvie F help
Discussion in 'Original Xbox' started by boxer29, Feb 9, 2012.
  1. boxer29
    boxer29 Member
    Sep 6, 2007
    330
    im runningn xbmc as my dash
    the e drive is almost full have got some emulators and games in it
    want to put emulators and games in drive F: which has got space
    how do i set the xbmc to look in both drives E and F for the emulators and games
    thanks
  2. boxer29
    boxer29 Member
    Sep 6, 2007
    330
    all sorted now
    put the games in F:
    the xbobx saw those by itself
    didnt need to change the path
  3. fallenangle
    fallenangle Member
    Oct 19, 2005
    404
    +24
    For stuff like that just use XBMC's File Manager to transfer them to the F:\drive. XBMC like UnleashX appear to be set to look in E, then, (assuming they've been formatted/enabled) F and G by default.
  4. Smooth911
    Smooth911 Member
    May 26, 2013
    Hello all,
    I have a problem I updated my modded Xbox with the new xbmc and it was not working so I deleted xbmc it was in the E/drive /apps/. Now my emulators disappeared I can see them in F/drive /emulators the file manager but how do I put back in the right drive so I can use them in the Xbox dashboard. I'm sorry if I posted in the wrong place.
  5. fallenangle
    fallenangle Member
    Oct 19, 2005
    404
    +24
    You should never delete an .xbe particularly your main dash without knowing exactly what you're doing. Best practice is to rename it to something bootable. In the event of such a failure the Xbox will look for a bootable .xbe on the same drive and use that.
    Question: with XBMC gone presumably, what dash are you using? If UnleashX or EvoX it could be that the Config.xml or .ini text files are, for some reason set up not to display the Emulator main menu option or are pointing at the wrong folder path.
    Emulators and XBMC are not really my area of knowledge in regard to the XBox so I recommend asking about this in the Xbox1 forum at Xbox-Scene for more specialist help.
