Email and blueyonder problem
Discussion in 'iPhone' started by MickEP, Aug 7, 2009.
  1. MickEP
    MickEP Member
    Dec 8, 2005
    451
    +58
    Hi hope someone can help me,
    I have just got my first iphone 3gs, and I am trying to set up the email option.
    I synced it with outlook and it seems to have the correct servers incoming and outgoing. the correct password and username.
    But when I receive new emails on my PC the are not showing up on my iphone.
    If I manually check for emails on the iphone, it does not give an error and seems to connect to the servers ok, but just wont detect any emails.
    Hope that makes sense :)
    Thanks Mick
  2. leeb-1977
    leeb-1977 Member
    Jan 6, 2009
    1,372
    +111
    list all of your settings mate and i'll check against the ones i have on mine - my blueyonder email address works perfectly with my iphone.
    (obviously dont list your password ;) )
  3. Steve170
    Steve170 Member
    Jan 25, 2005
    362
    28
    +37
    Do you mean you're downloading them on your PC first, then trying to get them on your iPhone? If so, you'll probably find the default setting on Outlook is to delete the mails from the server when they are read, so they will not be picked up by the iPhone once they've been downloaded on your PC.
    This is how it works with my blueyonder account at the mo. I think there is an option in Outlook (in the account settings) to leave the mail on the server so it would be picked up by your iPhone, though I haven't tried changing it yet.
  4. MickEP
    MickEP Member
    Dec 8, 2005
    451
    +58
    Thanks Steve
    I will have a look at that when I get home tonight
    Mick
    Thanks Leeb-1977 Heres my setting
    Host Name:pop3.blueyonder.co.uk
    User Name :(Not to sure if I can put this on here) but it is the same as on my PC
    Password: Same as on my PC
    Outgoing Mail Server: smtp.blueyonder.co.uk
    Use SSL: Off
    Authentication: Password
    Delete from Server: Never
    Server Port: 110 (same as on my PC)
  5. MickEP
    MickEP Member
    Dec 8, 2005
    451
    +58
    Thanks Steve That Sorted it :smashin:
