Eltax Symphony 8.2
Discussion in 'Speakers' started by paulw77, Jan 2, 2001.
  1. paulw77
    paulw77 Member
    Nov 18, 2000
    458
    +12
    Does anyone have an opinion on these speakers ? I have been offered some very cheap. Read on.
    I have a story to tell about Richer Sounds....
    On NYE I went in to buy a pair of Mission 702e's and a centre speaker (didn't know which one I wanted when I went in).
    THe manager offered me the Eltax Symphony 6.2's for the same price as the Missions (a saving of £90). I agreed and bought a matching Eltax Symphony centre.
    When I got the speakers home, I found they had given me one black and one beech (I wanted beech), so I took the beech one back. THe only beech one they had left was a display model, which was faulty. As I had not taken the other beech one with me (meaning another return journey) they have now offered me the Eltax Symphony 8.2's for the same price !
    This basicaly means I am getting a brand new pair of £250 speakers for the price of the Missions (£110 in beech).
    The thing is, I don't want them if they are crap. will they be too bassy for a room measuring 15x11 ?
  2. russraff
    russraff Member
    Aug 1, 2000
    2,248
    +43
    Personally, I would choose the Eltax over the Missions anyday. Thing is YOU might not. Book a demo and listen for yourself, its the only way to be sure.
    Russell
  3. aj
    aj Guest
    I would, (and did), choose the Eltax speakers.
    I had mine in a room about the size you quote and they were fine. Better than fine - damn good.
    I had mine paired with a Paradigm cc350 centre and cannot complain.
    If you can take your amp to to the RS dem roomand listen to them.
    Just cos I prefer them to the Missions doesn't mean you will.
    AJ
    PS They go well with the Eltax bipole rears.
  4. superhuman
    superhuman Member
    Jan 2, 2003
    446
    i have found the 8.2's to be have much smoother bass and a slightly crisper treble over the 702's but then they are twice the price (well, i paid twice the price anyway). if you can get them for £110 then that really is a true bargain.
    i have mine with the symphony centre and eltax monitor 3 rears, they all work great in my system
