Dune HD Base 3D - Official Thread
Discussion in 'Streamers & Network Media Players' started by PalmiNio, Jan 19, 2013.
Thread Status:
Not open for further replies.
  1. rolandrat
    rolandrat Member
    Oct 3, 2003
    417
    +25
    Be careful you not getting confused. The Dune HD base 3D is brand new, the Duo and Max are older models and not 3D compatible. (Apologies if you are aware)
  2. duckson
    duckson Member
    Nov 26, 2004
    684
    28
    +31
    Do you have the same stuttering problem if you ripped the blurays to BDMV folders?
  3. couto27
    couto27 Member
    Jan 9, 2012
    394
    +88
    when you have about 100BD ISO or more on the NAS its not really a option.
    Transfer 50GB (1x movie) from NAS> to External hard drive (usb wired)
    usb 2.0 =40m
    usb 3.0= 20m
    REMUX or MKV about 40m
    transfer 25gb remux from external hard drive to NAS (usb wired)
    usb 2.0 =30m
    usb 3.0 =10m
    Estimate total time to Remux 100BD ISO :
    usb 2.0=1h50m p/movie x 100 movies = 183 hours 20minutes
    usb 3.0=1h10m p/movie x 100 movies = 116 hours 40minutes
    ps: just ended to upload 12x mkv (25gb each) to NAS and took about 8 hours to complete
  4. acidraign
    acidraign Member
    Jan 21, 2013
    Does anyone have a list of online or retail stores selling the dune base hd 3d in the united states? i have only found one location and would like to find some others. Hopefully a brick and mortar store near me.
  5. Vision73
    Vision73 Member
    Jan 25, 2013
    13
    3
    Are there any information about how large harddisk's Dune supports via USB and locally? 3Tb / 4Tb? Thx!
  6. andreas77
    andreas77 Member
    Jan 18, 2013
    53
    In Sweden all Big Electronic reeseler have Dune Base 3d in stock so i belive it would be out everywhere next week.
  7. JSM15
    JSM15 Member
    Mar 15, 2008
    134
    +3
    There only appears to be one official reseller listed for Dune in the US at the moment - duneplayer.com - is this the site you're already aware of?
    They have the Base 3D listed for pre-order now at $299. Interestingly, the Zappiti version of the Base 3D is $50 more in the US! In Europe, both versions are the same price :p
  8. JSM15
    JSM15 Member
    Mar 15, 2008
    134
    +3
    If I were to buy a media player which couldn't handle at least 3TB drives, internally or externally, I'd be sending the thing back!
    The 'old' Dune players took 3TB internally, after a firmware update or two I believe, so I don't think you've got anything to worry about with the new Base 3D model.
    I'd be surprised if a 4TB didn't work internally either, though you'd want a 'green' drive inside it ideally, and I'd check online for a Dune HDD compatibility list as well.
  9. Denass
    Denass Member
    Jun 16, 2012
    312
    +19
    I use 3tb drives on mine no problems at all
    I have been using them on my base 3.0 for ages internally
    My friend uses his via a docking station
  10. Mr Eric
    Mr Eric Member
    Nov 21, 2011
    1,097
    +204
    3/4TB are no problem. The BAse 3D also have a fan for cooling, so I even would guess that 7200rpm drives wouldn't be a problem (would guess but won't bet on it :D)
  11. Denass
    Denass Member
    Jun 16, 2012
    312
    +19
    I only use 5400rpm as dune doesnt recommend 7200rpm drives
    The base 3.0 is identical layout inside as the base HD 3d looking at the photos
    I would say 7200rpm drives would be fine in a external docking station but would get a docking station with a fan to keep the drive cooler
    More docking stations should have fans
    When I am transfering huge amount of data between docking stations I have a very small fan blowing on them
    Had some drives getting very hot when transferring large amounts of data
    I tend to try to keep drives cool to help them last longer/hopefully
    Makes sense
    Really reinforces what I have been saying about alot of new media players with cramped environments and little to no ventilation
    here is what Dune says
    http://dune-hd.com/firmware/hw_compat/
  12. Vision73
    Vision73 Member
    Jan 25, 2013
    13
    3
    Thx guys!
    I was thinking to get Hitachi 4Tb Touro Desk USB3 (from Germany, 170€/227$)
    First using with USB and maybe later removing case and installing locally.
  13. JSM15
    JSM15 Member
    Mar 15, 2008
    134
    +3
    Be careful, there are two versions of the Touro. The 'Pro' version has a 7200 RPM drive inside, the DX3 model is 5400 RPM.
  14. Denass
    Denass Member
    Jun 16, 2012
    312
    +19
    Think the Dune HD Base 3D has
    3 x usb 2.0
    1 x usb 3.0 but this is a slave
    So an external drive might only be able to run @ usb 2.0
    The usb 3.0 wouldnt be able to run a external HDD
  15. MadScientist
    MadScientist Member
    Apr 30, 2006
    539
    +39
    If you can find a green 4Tb internal drive that is. I'm beginning to think that the Hitachi Coolspin 5K4000 doesn't actually exist
  16. Vision73
    Vision73 Member
    Jan 25, 2013
    13
    3
    This kind of use, isn't 5400rpm enough for playing 3D iso's via USB or internally?
    That external drive what I've was thinking to buy are 5400rpm.
    Could Dune read two external disks at same time or only one?
  17. Mr Eric
    Mr Eric Member
    Nov 21, 2011
    1,097
    +204
    5400rpm is plenty enough for file playback.
  18. Smurfin
    Smurfin Active Member
    Aug 13, 2002
    17,346
    +1,746
    You don't have to sit there all the time while the remuxing/file transferring takes place, just in case you didn't realise ;)
    Best stick to the older streamers then :)
  19. Smurfin
    Aug 13, 2002
    17,346
    +1,746
    Yes. Again, to reiterate: the problem is BD Lite, not anything else :)
    • Thanks Thanks x 1
  20. raif
    raif Member
    Jan 21, 2013
    27
    3
    +3
    Then, perhaps the next best option is to rip the 3d iso to mkv mvc but then dune base 3d doesn't support it yet - right?
  21. rolandrat
    rolandrat Member
    Oct 3, 2003
    417
    +25
    Not yet no, but new firmware in a few weeks is supposed to fix it, at the moment you get sound but no picture, the info button on screen even shows a high bitrate so its doing something, just not on screen!!
  22. duckson
    duckson Member
    Nov 26, 2004
    684
    28
    +31
    Roger that! :smashin:
  23. Nikitta
    Nikitta Member
    Jan 26, 2013
    2
    Hi all, my first post here!!
    A little question...
    I well intended that bd-lite is the only way to view a 3d BD iso file;
    is the same thing also for a standard 2d BD iso file or is still possible like my old Dune Base 3.0 to view 2d iso using full bd menus support?
    In other words bd-lite limitation works only on 3d or also in 2d BD isos?
  24. tim68
    tim68 Member
    Jan 7, 2007
    863
    +66
    hi all. i understand that this unit will not support full menu bd iso because of no bd licence due to cinavia protection. but will it support full menu dvd iso?, I plan to make full disc iso's of my classic doctor who dvd collection to play on my base 3d. thanks very much.
    Tim
  25. rolandrat
    rolandrat Member
    Oct 3, 2003
    417
    +25
    Not having many dvd rips myself but the few I have work just like the disk.
    • Thanks Thanks x 1
  26. MarkE19
    MarkE19 Moderator
    Aug 10, 2002
    15,894
    +2,087
    Welcome to the forum Nikitta :hiya:
    To get access to the BluRay disc menu requires the player to have a full BluRay license. So no new media players can display a disc menu regardless of if they are 2D only or 2D & 3D players as to get the license the player would be required to support Cinavia which would prevent Cinavia protected rips from playing and would therefore make the player useless :mad: . Only players that already had the full license before Cinavia support become mandatory can continue to offer disc menu access.
    Mark.
  27. dikkiedirk
    dikkiedirk Member
    Nov 10, 2007
    27
    As I understand it BD-lite is for all blurays incl 2D. That's why I stay with my Base 3.0.
  28. MarkE19
    MarkE19 Moderator
    Aug 10, 2002
    15,894
    +2,087
    IMO you would be far better using the likes of MakeMKV to rip the DVD to individual MKV files for each episode. You can then go directly to any episode without having to wait for the disc menu to load, and if using a video wall program you can easily see what each episode is.
    Mark.
    • Thanks Thanks x 1
  29. TW ALBIEE
    TW ALBIEE Active Member
    Jan 11, 2008
    2,537
    +125
    Is this a definite fix in the next firmware ?! I had a awful experience with a a400 and have now got a mede8er 600x3d which I am really impressed with but could do to move it to upstairs to replace a a300 and get a dune for the lounge ?!
  30. tim68
    tim68 Member
    Jan 7, 2007
    863
    +66
    thanks Roland.
    Hi Mark. thanks for your input. I watch the extras and listen to the commentries as much as watching the stories themselves, thats why i wanted to keep the discs intact as iso's. thanks for the thought though, much appreciated.
    Tim
Thread Status:
