B
BarryTra
Anyone no were I can get dulux icestorm paint.
Originally posted by Steviemac
Just finished painting my MDF screen in Icestorm and must admit that it does a really good job. Still have my black border to paint but overall I would say that Icestorm 6 is a good shade to use. I have a Sony VPL-VW12HT in case anyone was curious
Any recommendations for painting the wall a good colour to absorb most of the overspill from using it in a full through mode? Don't think my wife is too keen on an international matt black wall! lol
Jbev said:Vinyl Silk is quite reflective, more like an acrylic gloss.
Vinyl Matt should work but if you want a totally none reflective surface you should try Dulux Supermatt (not available in many colours) or Dulux Flat Matt (lots of colours, but might be only available in the trade paint and not retail)
What should you be looking for in a colour to paint the wall? If you let me know I can check the recipe for this colour and see what it contains.
Regards
Joel
fransisco said:Hi,
I moved to the US, and have been looking for some icestorm dulux paint. I finally found a retailer, but they ve never heard of IceStorm.
Apparently the name can change from continent to continent !!! Anyway, it seems that every color has a code formed of 2 numbers, 2 letters and then 2 numbers/3 numbers (exemple : 12AB 34/567). Does any one of you who used icestorm 5 or 6, has this number so I can get the right color... hopefully ?
Thanks for the help,
Fransisco
