DreamBox Dm800 & Dm8000 Owners Thread Pt1
Discussion in 'Satellite TV Forum' started by killz187, May 14, 2010.
  1. thfccambs
    thfccambs Well-Known Member
    Jul 17, 2002
    15,722
    +2,382
    Replied to your PM mate,
    for others it's on the latest DreamElite image.:smashin:
    Sent you all the info in the PM mate
    • Thanks Thanks x 1
  2. thfccambs
    Jul 17, 2002
    15,722
    +2,382
    Did you load new image mate?
    How did you get on?
  3. killz187
    killz187 Member
    Dec 2, 2008
    774
    +51
    Yes i did add on the new DreamElite image will give it a week to see how it goes.I was really used to the Nabilosat E2 Black hole image.I will give this a go for now,just need to do some more reading about this image.
    About the Dm8000 what size HD does it take?Is it the 2,5 or bigger?Im thinking of getting one but the price is putting me off at the moment.How is your box doing?Have you had any problems with it so far or not?
  4. Oily
    Oily Member
    Jun 11, 2007
    1,034
    +87
    3.5" internal HDD.Stick with the DE image,really fast and stable,I'm on the 1.3.3 version,has some nice skins as well
  5. jakey
    jakey Member
    Jun 13, 2005
    705
    43
    +112
    The DM8000 takes a 3.5" HDD.
  6. thfccambs
    Jul 17, 2002
    15,722
    +2,382
    Mine replaced skyhd and a DM800 so i needed more then 2 tuners, the DM8000 is perfect for me. I've had no problems at all with it, the odd crash when loaded something but nothing serious.
    Great sat box. :thumbsup:
  7. Oily
    Oily Member
    Jun 11, 2007
    1,034
    +87
    How about people post up what plug-ins they recommend/use and a general description of what they do :smashin:
  8. killz187
    killz187 Member
    Dec 2, 2008
    774
    +51
    That would be really a good idea:smashin:
  9. killz187
    killz187 Member
    Dec 2, 2008
    774
    +51
    Just got myself a o2 joggler running with Ubuntu based image ,should receive it tommorow can someone tell me how i can set this up with my Dm800?
  10. stubs
    stubs New Member
    May 28, 2008
    59
    I would also be interested in reading about how to do this :smashin:
  11. alpashm
    alpashm Member
    Sep 30, 2008
    98
    +13
  12. killz187
    killz187 Member
    Dec 2, 2008
    774
    +51
  13. lovelldr
    lovelldr Member
    Jul 19, 2006
    2,242
    63
    +151
    download all 10 files, and this will allow you to extract the contents using something like winrar...
  14. killz187
    killz187 Member
    Dec 2, 2008
    774
    +51
  15. JediBUZ
    JediBUZ Member
    Jan 24, 2008
    11
    +9
    Any one know if we are likely to get a DVB T2 tuner for DM8000?
  16. lovelldr
    lovelldr Member
    Jul 19, 2006
    2,242
    63
    +151
  17. Gliese 581c
    Gliese 581c Active Member
    Feb 3, 2002
    7,794
    +484
    got my dm800hd today :clap:
    Boy is it tiny, honestly I cant believe how small it is.
    Anyway, I'm gonna have to install a HDD, I assume its the 2.5" size ? any recommendations for a 500GB jobby that works well ?
  18. lovelldr
    lovelldr Member
    Jul 19, 2006
    2,242
    63
    +151
    When I had my 800, I used a wd blue scorpio 500 drive. Worked perfectly, just I ran out of space on it :p hehe
  19. aris
    aris Member
    Aug 26, 2002
    209
    +13
    How much disk space does the 800 use when recording SD or HD per hour of recording?
  20. lovelldr
    lovelldr Member
    Jul 19, 2006
    2,242
    63
    +151
    All depends on the channel you're recording, and the bitrate it's recording. Most uk hd channels that I've recorded, record at a rate of around 4.5 - 5.5 gb per hour. On a swedish HD channel I'd recorded, that was at a rate of around 7.2 gb per hour...
    As for sd, on most uk channels, that's recorded at around 1.75 gb - 2.15 gb per hour...
    • Thanks Thanks x 1
  21. aris
    aris Member
    Aug 26, 2002
    209
    +13
    What format is it recorded in - and is it easily transcoded to something like xvid?
  22. lovelldr
    lovelldr Member
    Jul 19, 2006
    2,242
    63
    +151
    Not sure about the exact encoding, but it's inside a .ts container. I wouldn't have thought it'd be too much of a hassle to convert to xvid or such like. They play straight away on most pcs iirc when transferred over. Have also transferred some quite easily to dvd before (SD obviously, not HD)...
    hth
  23. thfccambs
    Jul 17, 2002
    15,722
    +2,382
    Hows the DM going?
  24. Gliese 581c
    Feb 3, 2002
    7,794
    +484
    Image on and ready to rock and roll. Got a 640GB drive coming for it, £49 from CCL so not too bad, and the sat dish is being installed on Wed morning :)
    Will let you know when its running.
  25. aris
    aris Member
    Aug 26, 2002
    209
    +13
    Are you using a real DM800 or a clone?
  26. Gliese 581c
    Feb 3, 2002
    7,794
    +484
    A clone. BL76, 2.01 and Tuner L3
  27. aris
    aris Member
    Aug 26, 2002
    209
    +13
    Did you buy it locally or import? I'm on the cusp of buying one - but i'll be buying locally to avoid any heartache.
  28. Gliese 581c
    Feb 3, 2002
    7,794
    +484
    I bought mine from ukdreamshop
    Based in the UK which helps, and also the guy there gives brilliant service.
  29. fruityloop
    fruityloop Member
    Jan 30, 2009
    260
    +14
    its where i got mine from.great service.had mine a week now.not impressed with gemini 5 image it comes with though.i put dream elite on mine.runs superb now.
  30. aris
    aris Member
    Aug 26, 2002
    209
    +13
    I just have had delivery of mine from Worlds No.1 HD satillite receiver - DM8000 - delivered in 24 hours - good stuff.
    I'm new to this - so it will be a learning experience. Is there any place I can find out about the differences between the different images? Which is best?
