Does Sky+ HD box need to be connected to phone line ?
Discussion in 'Sky Forum' started by drumbeat, Jan 31, 2009.
  1. drumbeat
    drumbeat Member
    Dec 2, 2008
    79
    +4
    As the title says, is this necessary if only having Sky Tv and NOT the Broadband and Phone options .
  2. SkyVanMan
    SkyVanMan Member
    Oct 13, 2008
    160
    +20
    You can have sky hd without a phoneline, but you would have to pay around 25quid i think, for a "no phone line install". You could not have multi-room without a landline.
  3. GasDad
    GasDad Remembered (1964-2012)
    Mar 28, 2006
    5,392
    +766
    If you don't want to pay the premium, and assuming you have a landline, simply run a phone extension cable to the sky box and unplug it when the installer has left. You'll have to plug it in again to order PPV movies etc.
  4. Atomic_guy
    Atomic_guy Member
    Jan 25, 2009
    57
    I am in similar situation. I do not have a BT line. When I've ordered Sky+HD from Sky.com site I had to tick one of the tick box that says I will have to pay £25.
    I am with virgin media.
    Sky website wont let me select Sky talk or Sky broadband.
    How do I get around this?
  5. Delvey
    Delvey Active Member
    Jul 20, 2008
    5,936
    +864
    you cant, virgin media own there own lines, while BT signed some agreement or something allowing there lines to be used by other companies. Im sure someone will explain in more detail
  6. BrianMc
    BrianMc Member
    Dec 18, 2007
    1,262
    63
    +156
    BT are the dominant operator and OFCOM force them to allow others access to their lines and exchanges - Virgin are not!
  7. wbabbington
    wbabbington Active Member
    Mar 8, 2008
    2,475
    +277
    £25!:eek:
    Mine hasn't been connected to a phone line for over a year (I just unplugged it) and never even mentioned a "no phone line install". Had no problems whatsoever, all channels/Anytime/recordings/planner etc work perfectly well.
    If you dont want to do any interactive stuff then unplug it.
  8. Delvey
    Jul 20, 2008
    5,936
    +864
    excellent explanation
  9. Tfish
    Tfish Member
    Jan 18, 2009
    319
    +7
    its possible for £200 box only no contract, see the tesco offer thread
  10. GasDad
    Mar 28, 2006
    5,392
    +766
    It is possible for the 49quid offer as well
    The OP is Not having broadband or phone lines through sky.
    All that is required is that a phone line is available during installation. Assuming he has a landline somewhere in the house, a 5 quid phone extension cable will satisfy this requirement.
    Should he decide to order box office movies in the future, he'll have to get the extension cable out again.
  11. dmaidmen
    dmaidmen Member
    Nov 25, 2006
    457
    +71
    The Sky engineer that performs the install should run the extension cable to the phone point. If you arn't going to leave it connected just ask him to run it direct and you'll put it around the skirting boards etc.. later. When he's gone just disconnect it. As mentioned above you can always shove it back in if you want to order something or do a call back to sky.
    Duncan
  12. Miss Chief
    Miss Chief Active Member
    Jun 12, 2007
    7,650
    +1,111
    If you don't want the phone and/or broadband then your Virgin media line will be just fine. As long as it's a landline that allows incoming and outgoing calls it doesn't matter that it's not a BT line.
